If you can keep them close to $25/ea., put me down for a couple. I'll probably use at least one them to help our son get into home-made computers without having to wire-wrap another one. He's done some C64 assembly programming, but this will afford a different kind of work, with fuller control over the entire project.
I don't think I need any more parts myself, and the first quantity price break for most places that will sell one part at a time may not be worth the double shipping unless you send the parts out with the board itself.
WDC does have a $100 minimum order, but their VIAs have the faster totem-pole outputs on the IRQ line that can't be wire-ORed like older VIAs and like your board does. Since you haven't gotten the board built yet, maybe it would be good to add a series diode in the IRQ line of each VIA. (I should have brought this up earlier.) I expect the VIA could still pull the voltage low enough that the processor would recognize a valid low logic state and respond to the interrupt. If silicon diodes have too much voltage drop, there should be a small shotky diode that would do the job. Worst come to worst, the diode space on the board could be jumpered and you use non-WDC VIAs. In other words, you'll probably gain something but you won't lose anything by adding the diode spaces.
California Micro Devices' (CMD's) parts are not as fast as WDC's (only spec'ed to 6MHz). Their distributors are:
Arrow Bell Components
www.arrow.com El Segundo, CA branch: (310)563-2348
Jaco Electronics
www.jacoelectronics.com Hauppauge, NY (800)541-9371
These are industrial distributors. Such distributors have line cards, but usually no catalog. They don't usually mind selling to hobbyists, but they usually have minimum orders (like $100) and you should be prepared with exact manufacturer's numbers you want and acceptable substitutes (like a wider temperature range or faster speed) if your first choice would take too long to get. CMD still makes the 65c51, but I don't believe WDC ever did. For my own future projects, I may just use UARTs with I2C interfaces so the processor can communicate with them without slowing down to 4 or 6MHz. I have 100 1MHz 6512 processors here. I'd like to keep a few, but I might be willing to let most of them go for a reasonable price. The 6512 is like an NMOS 6502 without an on-board clock generator. Boards can be made with a couple of jumper options to accomodate the 6502 or 6512 either one.
To again mention a couple of hobbyists' sources of 65xx parts:
Debco Electronics
www.debco.com/db_online/micro.htm#6000Jameco Electronics
www.jameco.comHappy building, happy programming, and all that good stuff.
Garth
