It is currently Sat Nov 23, 2024 11:53 am
 Post subject: Pong game optimization
PostPosted: Tue Apr 09, 2013 2:25 am
Hey guys, this is my first post here on the forums, as well as my first program for the 6502. I wrote this with Skilldreck's "6502 Easy" online emulator. So far I just have the player one movement done. Use the W and S keys to move the paddle up and down. The concept works, but I have a sneaky suspicion that the program can be drastically optimized, especially where I do the paddle index increment/decrementation. I also have not yet added code to restrict the paddle from moving outside of the screen boundries (a quick CMP should do, correct?). Let me know what you think. Your considerations are appreciated.
-Daniel
lda #$00
sta $00
lda #$02
sta $01
lda #$00
sta $03
lda #$02
sta $04
;$00--->low address pointer to paddle index
;$01--->high address pointer to paddle index
;$03--->paddle origin low
;$05--->paddle origin high
loop:
  lda $03       ;reset paddle draw indexs
  sta $00
  lda $04
  sta $01
  jsr drawPaddle
  jsr readKeys
  jmp loop
drawPaddle:
  ldy #0
  lda #3       ;set color of player 1
  sta ($00),y  ;write that bit to display
  lda $00
  adc #$20     ;incr to next pixel of paddle
  sta $00
  lda #$00
  adc $01
  sta $01
  ldx $02      ;incr the counter till 5
  inx
  stx $02
  cpx #5
  bne drawPaddle
  lda #$00     ;reset counter for next run
  sta $02
  rts
readKeys:
  lda $ff
  cmp #$77
  beq upKey
  cmp #$73
  beq downKey
  rts
upKey:
  clc
  lda $00    ;decrement paddle draw index
  sbc #$1f
  sta $00
  lda $01
  sbc #$00
  sta $01
  clc
  ldy #$00    ;clear previous pixel
  lda #$00
  sta ($00),y
  lda $03    ;decrement paddle origin
  sbc #$1f
  sta $03
  lda $04
  sbc #$00
  sta $04
  clc
  lda #$00
  sta $ff
  lda $ff
  rts
downKey:
  clc
  lda #$00
  sta ($03),y
  lda #$20    ;increment paddle origin
  adc $03
  sta $03
  lda #$00    ;increment the high byte of origin
  adc $04
  sta $04
  lda #$00
  sta $ff
  lda $ff
  rts
gameover:
  brk
PostPosted: Thu Apr 11, 2013 6:55 am
Hi Daniel -- and welcome!
Nothing like a little game to practice programming skills! I can see you're off to a good start with this.
My first suggestion is that you give symbolic names (labels) to the memory locations you're using, and then always refer to the locations by name. Maybe that seems like more trouble, but once you get in the habit it will pay off in the long run. That's because the code will be much more readable, both to others and to yourself -- and mistakes and opportunities for improvement will become more obvious. For example if you say
PaddleIndexL    =$00   ;low address pointer to paddle index
PaddleIndexH    =$01   ;high address pointer to paddle index
then later you can say
  lda PaddleIndexL
  sta PaddleIndexL
  lda #$00
  adc PaddleIndexH
  sta PaddleIndexH
which is much clearer than your original code, isn't it.
I've only looked at the first portion of the program... partly because it's hard to read. (The comments are helpful at least.) Here are a few pointers. First, an addition sequence like the one above usually requires a CLC instruction as a prelude. You can omit the CLC if you know the Carry flag will already be clear, but these sorts of assumptions can cause trouble when you modify the code later, so always include the CLC or at least make an appropriate warning comment.
There's another little bug regarding location $02, which is not initialized to a known quantity before the first call to drawPaddle. The emulator might provide a consistent starting value in $02 without being asked to do so, but the memory in an actual computer is not so obliging! When the program starts (before the first call to drawPaddle) you need to go
  lda #$00           ;reset counter for very FIRST run
  sta Counter
(Notice I've chosen a name for the memory location.)
Care to polish up your code and post it again? Then we can advance from bug fixes to some potential optimizations! :D
cheers,
PostPosted: Sun Apr 14, 2013 11:31 am
Hi Jeff, (and Daniel- welcome)
unfortunately Nick's mini-assembler in easy6502 doesn't fully handle symbols in the way we normally expect an assembler to. So your suggestion would need to be modified to use this trick:
*=$00
PaddleIndexL:   ;low address pointer to paddle index
*=$01
PaddleIndexH:   ;high address pointer to paddle index
*=$600
My fork of the easy6502 simulator does a slightly closer approximation to a symbolic assembler, which will accept your suggested syntax: see
http://biged.github.com/6502js/
PostPosted: Sun Apr 14, 2013 3:08 pm
Thanks for the correction, Ed. I had a feeling I might be on shaky ground with that. :) I'm aware that syntax can vary but I didn't look into the specifics in this case.
PostPosted: Mon Apr 22, 2013 12:17 am
Yes, i was going to say that Nick's version didn't implement any symbolic labels for addresses... except for JSR (I contacted him, and looked through his source code to find some possible methods, but no success) Thanks BigEd I'll have to check out your version of the assembler/emulator. I have added portions to the code that restrict the movement of the paddle within the boundraries of the screen, as well as cleaned a few other things up. Hopefully I will port my code to BidEd's emulator and see if I can fully utilize labels, and repost the new code.
PostPosted: Mon Apr 22, 2013 1:06 am
Okay, I've labeled all of my memory locations, and have commented a bit more thoroughly. Here's the code, and please assemble it using BigEd's version of 6502easy.
BigEd's 6502easy: http://biged.github.io/6502js/
paddleIndexL  = $00
paddleIndexH  = $01
paddleOriginL = $03
paddleOriginH = $04
loopCnt       = $02
;$04--->paddle origin high
jsr init
jsr loop
init:
  lda #$00
  sta paddleIndexL
  lda #$02
  sta paddleIndexH
  lda #$00
  sta paddleOriginL
  lda #$02
  sta paddleOriginH
  lda #$00
  sta loopCnt
  rts
loop:
  lda paddleOriginL  ;reset paddle draw indexs
  sta paddleIndexL   ; because they are modified
  lda paddleOriginH  ; by the drawPaddle routine.
  sta paddleIndexH   ; Must be set back to "origin"
  jsr drawPaddle
  jsr readKeys
  jmp loop
drawPaddle:
  ldy #0
  lda paddleIndexL
  sta paddleIndexL
  lda #$00
  adc paddleIndexH
  sta paddleIndexH
  ldx loopCnt  ;incr the counter till 5
  inx
  stx loopCnt
  cpx #5
  bne drawPaddle
  sta loopCnt
  rts
readKeys:
  lda $ff
  cmp #$77
  beq upKey
  cmp #$73
  beq downKey
  rts
upKey:
  clc
  lda paddleOriginL ;****see if paddle near edge****
  adc paddleOriginH ;add the hi and lo of origin
  cmp #$02          ;is origin at top of screen?
  clc
  beq onEdge
  clc
  lda paddleIndexL
  sbc #$1f
  sta paddleIndexL
  lda paddleIndexH
  sbc #$00
  sta paddleIndexH
  clc
  ldy #$00
  lda #$00
  sta ($00),y
  lda paddleOriginL
  sbc #$1f
  sta paddleOriginL
  lda paddleOriginH
  sbc #$00
  sta paddleOriginH
  clc
  lda #$00
  sta $ff
  lda $ff
  rts
downKey:
  clc
  lda $03     ;****see if paddle near edge****
  adc $04     ;add the hi and lo of paddle origin
  cmp #$65    ;is origin 5 pixels above bottom
  clc
  beq onEdge
  clc
  ldy #$00
  lda #$00
  sta ($03),y
  lda #$20
  adc paddleOriginL
  sta paddleOriginL
  lda #$00
  adc paddleOriginH
  sta paddleOriginH
;clear the keyboard buffer
  lda #$00
  sta $ff
  lda $ff
  rts
onEdge:       ;returns program when paddle reaches
  rts         ;the edge of the screen
gameover:
  brk
PostPosted: Mon Apr 22, 2013 3:03 am
Even if you have an NMOS 6502 (not the CMOS one with more instructions and addressing modes, especially in this case the STZ which allows you to store zero in a memory location without first loading it into the accumlator), you can still shorten things up. With just a quick look (and not delving into the actual operation of the game):
init:
  lda #$00
  sta paddleIndexL
  lda #$02
  sta paddleIndexH
  lda #$00
  sta paddleOriginL
  lda #$02
  sta paddleOriginH
  lda #$00
  sta loopCnt
can become:
init:
  lda #00
  sta paddleIndexL
  sta paddleOriginL
  sta loopCnt
  lda #2
  sta paddleIndexH
  sta paddleOriginH
  lda #$00
  adc paddleIndexH
  sta paddleIndexH
can become:
  bcc 1$
  inc paddleIndexH
1$:
  inx
  stx loopCnt
  cpx #5
can become:
  inc loopCnt
  ldx loopCnt
  cpx #5
but it doesn't look like you're using the actual X value, just using it to count; so it would be more efficient to load it with the number first, then count down instead of up (since there's an automatic compare-to-zero built into so many instructions), and just do:
  dex
  bne drawPaddle
  lda paddleIndexH
  sbc #$00
  sta paddleIndexH
can become:
  bcs 2$
  dec paddleIndexH
2$:
  ldy #$00
  lda #$00
  sta ($03),y
can become:
  ldy #$00
  tya
  sta ($03),y
to save a byte.
  lda #$00
  adc paddleOriginH
  sta paddleOriginH
can become:
  bcc 3$
  inc paddleOriginH
3$:
and in
  lda #$00
  sta $ff
  lda $ff
the lda $ff is redundant and unnecessary because you'll load the accumulator with the value it already had anyway.
I have more program tips at http://wilsonminesco.com/6502primer/PgmTips.html
PostPosted: Mon Apr 22, 2013 3:28 am
Woah thanks a lot GARTHWILSON. Just the kind of stuff I was looking for. I'll have to look through most of this some other time, but its a start. Hopefully by next weekend I can have an improved version. I can see how most of my code was redundant and therefore hogging up clock cycles.
PostPosted: Mon Apr 22, 2013 7:53 am
That's quite normal for a first attempt! In fact I helped Nick tidy up some of his code for the "snake" game in his tutorial. I'm sure there are still a few non-idiomatic bits of code in there.
Of course, getting it right first is a good idea... then doing the peephole optimisations. Over time, you become more fluent and your first effort will be more idiomatic.
Users browsing this forum: Google [Bot] and 12 guests
