It is currently Sun Nov 24, 2024 3:26 am
PostPosted: Thu Apr 04, 2013 2:29 pm
I have these two devices (available from http://bitfixer.com ) and they both work very well. What I want to do is this:
With the PETvet, I want to replace the ROM images with my own code. With the PETdisk, I want to add some functionality like direct block I/O, implement other PET 8250 disk commands, and cassette simulation.
There are a couple of include files missing from the sources which I haven't been able to obtain from the vendor. I tried reconstructing them on my own. Trouble is, I'm not much with programming the Atmel chips and my C is rusty.
Has anybody here played with these devices and/or feels comfortable with the Atmel 8-bit microcontroller chips to help me?
Thanks
Charlie
PostPosted: Fri Apr 05, 2013 7:42 am
Which files are missing? And what are you using to compile?
PostPosted: Tue Apr 30, 2013 1:42 am
In terms of forums that could help you, I would try Arduino.cc, Nerdkits.com, protostack.com and AVRFreaks.net if you can get on (AVR Freaks) it.
There are lesser known forums that don't specialize in AVR.
Let us know how you make out.
PostPosted: Thu May 02, 2013 4:41 pm
It has been some months since I looked at it. The source was missing one of the include files for (I think) PETdisk. I used the Atmel libraries on Linux (there's no Atmel Studio build for Linux) and tried getting the project to build in Atmel Studio 6 on a Windows box. No joy. I would like to say it's a very high priority project. I would like to say that.
In other news, I found my C2N datasette deck last weekend. This weekend I'll be setting up another tower, this one with Windows 7 on it, so I'll finally have a Windows machine on my desk at home.
Charlie
PostPosted: Sun May 19, 2013 2:07 am
Yes I had the same issue when I tried to compile the source under Linux.
I've created a patch which includes:
- the missing UART_routines.h header file (re-created).
- a GNU Makefile.
- a lot of minor changes to silence the many compiler warnings.
I've sent the patch to Michael Hill (bitfixer) along with some questions, he has yet to respond.
I've attached the patch file. Let me know if you run in to any problem as I've played with the PETvet quite a bit -- even managed to let out some of the magic smoke, unfortunately :cry:
File comment: PETvet v1.0 patch: UART_routines.h and Makefile
PETvet10.patch.gz [3.55 KiB]
Downloaded 90 times
PostPosted: Sat Jun 15, 2013 9:07 am
How much RAM do those AtMegas have? If enought (2k?) there already are other solutions like sd2iec or XD2031 firmwares in that case with much more functionality already in them.
Or do you do it for the experience? ;-)
André
