It is currently Tue Sep 17, 2024 3:38 am
 Post subject: SBC and Carry
PostPosted: Thu Apr 04, 2013 5:21 am
So, I managed to get the simulator proof test running on my simulator, and I've found several issues.
I'm down to decimal mode.
I have this sequence. This is the 'chkdad' routine for those following along at home. This shows the address, instruction, status, registers, and the top part of the stack ($1FF down to, I dunno, $1F5 or so...)
3cd3: PHP              -- -O*-D--C A:a0 X:58 Y:ff S:fb 3c 7b 7a f8 ff 32 fd 30 0 0 0
3cd4: LDA $57          -- -O*-D--C A:a0 X:58 Y:ff S:fa 3c 7b 7a f8 79 32 fd 30 0 0 0
3cd6: ADC $58          -- -O*-D--C A:1 X:58 Y:ff S:fa 3c 7b 7a f8 79 32 fd 30 0 0 0
3cd8: PHP              -- -O*-D--C A:1 X:58 Y:ff S:fa 3c 7b 7a f8 79 32 fd 30 0 0 0
3cd9: CMP $59          -- -O*-D--C A:1 X:58 Y:ff S:f9 3c 7b 7a f8 79 79 fd 30 0 0 0
3cdb: BNE $3cdb        -- -O*-D--C A:1 X:58 Y:ff S:f9 3c 7b 7a f8 79 79 fd 30 0 0 0
Also, here's the content of the $0050-005F, which does not change in this process:
       0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
0050: 59 02 59 01 5a 01 00 01 99 00 01 02 00 42 52 00
So it's LDA $57, which is 01, and then it ADC $58, which is 99, with Carry set, in Decimal mode. I have this coming out at $01 (99 + 1 + 1 = 101, mod 100 = 1), with carry set. But the test is comparing it with $59, which is a zero. Am I missing something here? Why would ADC be set to 0?
 Post subject: Re: SBC and Carry
PostPosted: Thu Apr 04, 2013 8:18 am
There is two calls of the decimal add & subtract routine "chkdad". One is with carry clear, the other with carry set. You can distinguish them by looking at $56 which is "adfc", 1 for carry set, 0 for carry clear. According to this "chkdad" was called with a CLC ahead of it but carry in the processor status is on.
You need to find the place where the carry is illegaly set or not cleared.
PostPosted: Thu Apr 04, 2013 2:31 pm
Ah, thank you so much. I've been managing to bumble through the rest of this with only a basic understanding of how the test works, rewrote my math routines from scratch, but this one was flummoxing me. I will look at it later when I return from a trip.
PostPosted: Thu Apr 18, 2013 4:15 am
Yay!
It works!
None of my CLx routines were working, it turned out. So, CLC was failing.
Then I had a final problem with ADC in Decimal, where 99 + 1 was turning in to "A0"...doh! One off error for carry.
But now it passes (I get to the JMP $3CD0 spot...).
Now I need to add interrupts and reset and those bits to it. Clean up the UI.
Thanks for the help, and thanks so much for the test suite.
PostPosted: Thu Apr 18, 2013 9:50 am
CLC and all other CLx opcodes are checked earlier in the test. Was this going undetected?
; test set and clear flags CLC CLI CLD CLV SEC SEI SED
        set_stat $ff
        clc
        tst_stat $ff-carry
        sec
        tst_stat $ff
; ... continues to test I, D & V, then tests reverse flags
        set_stat 0
        tst_stat 0
        sec
        tst_stat carry
        clc
        tst_stat 0
PostPosted: Thu Apr 18, 2013 5:32 pm
Well, I looked through it and I think that the CLC/SEC check was working in that case, but it was clearly failing in the other case. Now, CLC is a pretty simple routine.
What I had before, in Java, was:
status &= ~(CARRY_MASK);
And in context of the ADC tests, this was apparently not sufficient. So I changed it to:
status &= ~(CARRY_MASK) & 0xff);
That was enough to make it work.
I tried to change it back to what it was, and all the tests pass, so something else I may have done added to the repair.
But when I was initially testing, I stepped over CLC, and saw the C flag bright as day, so at the time, that was the correct solution.
PostPosted: Thu Apr 18, 2013 6:48 pm
Strange, because the second version shouldn't make a difference except the extra closing parenthesis, which is probably just a typo in the example but not present in your code.
