It is currently Sat Nov 23, 2024 12:49 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Mon Dec 10, 2012 10:05 pm
After a hard working weekend adapting the code from AVR Assembler to gcc this is the final result: A beautiful sync between clock and chipsel for the 6522.
ATMega @16MHz, 1MHz OC0B with Timer 0, CS=1 active, while loop calls sync_wrt() repeatedly. If you watch closely you even can see the fingerprint of the code, 7+1 clock cycle for the NOPs causing the voltage drop respectively.
Nice.
Thank you, Klaus.
Users browsing this forum: Google [Bot] and 14 guests
