It is currently Sat Nov 23, 2024 5:38 am
 Post subject: Opening chips
PostPosted: Thu Nov 22, 2012 5:46 am
I found a post on hackaday about melting the plastic package with boiling acid. And they opened quite a few chips already and posted some pictures:
http://zeptobars.ru/en/read/how-to-open ... hat-inside
I contacted them and i also asked if they would open donated chips, and they will. I got their address so if anyone has some chips to boil in acid we could donate them and find out what is hiding inside.
Lets try to make a list(if anyone wants to donate) before donating anything and send it to see if they agree with it.
 Post subject: Re: Opening chips
PostPosted: Thu Nov 22, 2012 2:08 pm
In the 90's, I read an article that AMD took a razor blade to chips, scraped a chip and photographed it. They scraped the chip again and photographed it. They used several chips and took thousands of pictures. This would help you get a picture of what is inside. You don't always need to use acid on a chip. Be careful with acid, because some acid won't come out of your skin. And be careful playing with blades.
PostPosted: Thu Nov 22, 2012 2:34 pm
Hehe, you was talking to me ;-)
So we may discuss it right here.
PostPosted: Thu Nov 22, 2012 3:40 pm
Welcome to the forum!
What chips did you plan to open next?
PostPosted: Thu Nov 22, 2012 5:13 pm
Already decapped but not published are Z80, kr580vm80a, MC34063, RTL8111 and ALC888.
Then I am thinking decapping bunch of transistors (FET and BJT) to see differences, and some very simple CMOS logic which could be good example for reverse engineering.
PostPosted: Thu Nov 22, 2012 5:57 pm
Hi Bars, and welcome!
Do you have the means, and the interest, to strip the metal and re-photograph? I'm thinking, of course, of reversing the transistor netlist, like visual6502.
Edit to add: nice photos by the way! I'd be interested to see some floorplan of the ST chip, to see where the ARM is.
Edit: the ARM M3 core is apparently just 33k gates, and anything from 0.43mm2 in a 0.18u process down to 0.03mm2 in a 40nanometer process. That ST chip is 8.9mm2, so we're looking for something which is 1/20th of the chip, if it's in 0.18u. But probably it's a 90nm process, so we're looking for an 80th of the chip. But then, looking at pages 24 and 25 of this pdf there might be nothing organised to see!
PostPosted: Thu Nov 22, 2012 6:05 pm
I was stripping metal on kr580ik80a (i8080-compatible) - should be easy on any chips with only 1 metal.
Doing so on more modern chips (like STM32) is near limits of optical microscopy and multiple metal layers would cause lots of pain.
PostPosted: Thu Nov 22, 2012 6:10 pm
That's fine - all the best chips are single metal!
Did you notice John McMaster seems to be making some progress with opencv?
http://uvicrec.blogspot.co.uk/2012/11/s ... -ehsm.html
PostPosted: Thu Nov 22, 2012 6:11 pm
Hey, welcome to our 6502 world!
