HDL Implementation of Video Generator Test for 16-bit PVB's
ElEctric_EyE
Re: HDL Implementation of Video Generator Test for 16-bit PV
OK Finally got it working! Closeup of the upperleft portion of the monitor. This is ramping RGB from high to low. Noise issue is gone as well.
ElEctric_EyE
External control of the PROM select and FPGA /Program works as expected. 2 different patterns were programmed and selected successfully. Good news is PROM 1 & 2 designations on the board matches up with ISE. When ISE initiates the JTAG scan it shows the leftmost PROM (1), the middle PROM (2) and the FPGA on the right.
I think it's time to solder in the SyncRAM and try to come up with some simple HDL to try reading from it.
- BigDumbDinosaur
Looks like designer vertical window blinds.
ElEctric_EyE
Guys, thanks! Very excited here. I soldered in the .65mm SyncRAM. Overdid it with the solder and used braid to get excess off. I like this technique! Will use it from now on. PVB powers up and runs still and no smoke...
Now I've been busy with some code and cannot use a testbench since there's no way to simulate the RAM. But I have made a successsful symbol with all the I/O's present, so the ISE tool must think it knows what I want to do. I've tried to approach it logically. Here goes:
module SRAMif( output reg [20:0] SRA = 0,
output reg WEn = 1,
output reg SRCLK = 0,
output reg SRCS = 0,
input [15:0] SRD,
output reg [4:0] Red_data,
output reg [5:0] Green_data,
output reg [4:0] Blue_data,
input clk50,
input pclk,
input hstart,
input vstart,
input hblank
reg [15:0] SRDtemp;
reg countflag;
always @(posedge clk50)
SRCLK <= ~SRCLK; //pixel clk is SyncRAM clk
if ( hstart & vstart ) //reset address counter at top left of screen
SRA <= 0;
if ( pclk )
if ( hstart )
countflag <= 1; //countflag active in display area
else if ( hblank )
countflag <= 0;
if ( countflag )
SRA <= SRA +1; //increment RAM address counter
if ( pclk & countflag )
SRDtemp <= SRD; //latch incoming data
begin
Red_data <= SRDtemp [15:11]; //outgoing data to videoDAC
Green_data <= SRDtemp [10:5];
Blue_data <= SRDtemp [4:0];
end
endmoduleRe: HDL Implementation of Video Generator Test for 16-bit PV
In any case, try not to use really dry braid. If it works too well, it sometimes leaves too little on the pin. Instead, if it gets saturated, only cut off the end, but leave the half-saturated part. It's a matter of trial and error and experience to see how much you need.
ElEctric_EyE
Arlet wrote:
...In any case, try not to use really dry braid. If it works too well, it sometimes leaves too little on the pin. Instead, if it gets saturated, only cut off the end, but leave the half-saturated part. It's a matter of trial and error and experience to see how much you need.
Last post with code passed syntax check and was able to make a symbol, but it did not synthesize. SRA was a reserved name, so had to change it, also SRCS was wrong value. I did not have the SyncRAM address outputs registered like I did with the databus outputs and got a multiple driver error. So I fixed it, and it passes sythesis. I tried it out. Getting totally random pixels all the time. Timing not right. But it's something!
module SRAMif( output reg [20:0] SRAddr = 0, //SyncRAM address bus
output reg WEn = 1, //SyncRAM R/W, always read
output reg SRCLK = 0, //SyncRAM clock
output reg SRCS = 1, //SyncRAM chip select
input [15:0] SRD, //SyncRAM databus
output reg [4:0] Red_data, //
output reg [5:0] Green_data, //videoDAC databus, always write
output reg [4:0] Blue_data, //
input clk50, //50MHz main clock
input pclk, //25MHz pixel clock
input hstart,
input vstart,
input hblank
reg [20:0] SRAddrtemp;
reg [15:0] SRDtemp;
reg countflag;
if ( pclk )
if ( hstart )
else if ( hblank )
countflag <= 0;
SRAddrtemp <= 0;
else if ( countflag )
SRAddrtemp <= SRAddrtemp +1; //increment RAM address counter
begin
end
SRAddr <= SRAddrtemp; //outgoing address
endmodule
Are the pixels stable, or are they flickering ?
ElEctric_EyE
Always changing, like my address counter is not being reset.
EDIT: I will go back to the simulator and see how your HVSync module works.
Here's a verilog model of the RAM
ElEctric_EyE
Thanks for looking that up. I'm sure i will need that in time, but now I know my problem is that the RAM counter is not being reset. My logic for resetting it using hstart and vstart is wrong. I must determine how to tell it the last pixel has been displayed. Maybe I could generate this signal from within your vga.v HVSynv module?
Here's a problem:
The hstart and vstart pulses don't happen at the same time. Try resetting the address counter just based on vstart. The vstart signal comes early, so you can prepare the data path. At hstart, you start incrementing.
You'll still have artifacts because the code doesn't compensate for all the pipeline delays, but at least you should have a stable picture.
ElEctric_EyE
Arlet wrote:
...You'll still have artifacts because the code doesn't compensate for all the pipeline delays, but at least you should have a stable picture.
I'm aiming for a stable pixel generation (i.e. data from a fast read-only memory (in my initial test), non-FPGA Block Memory, but similar) and should be able to achieve it at such a low pixel clock (25 MHz, 40ns access time) without even looking at timing diag's. Hopefully this pass-thru synchronous RAM has a 6.5ns delay, not pipelined like the other versions of this Synchronous RAM.
EEyE:
This comment is not going to help, but I suggest that you use a single clock for the SRAM. Your comment on the following code says it, so I would recommed using pclk as the clock source for the SRAM.
However, instead of using an assignment statement (and its potential path delays), I would suggest clocking the SRAM in the following manner:
This will allow pclk == 1 to function as the enable for input FFs in the IOBs, which appears to be already included in your SRAM interface module.
Thinking on this a bit more, I suggest that you need to look at the path delays in the IOB relative to the SRCLK and pclk. My understanding of the signal timing means that your use of the same phase of the clock (pclk and SRCLK should be in-phase) means that you are sampling the data in the middle of the cycle instead at the end of the cycle. I expect that the data may not be stable at that point, or if it is, you have not applied a NO_DELAY attribute on the input buffer of the FPGA. In either case, the data is clearly not stable, unless of course the SRAMs are not initialized.
The changes I suggested above should alleviate this timing issue.
SRCLK <= ~pclk; //pixel clk is SyncRAM clk
Michael A.
ElEctric_EyE
That does help. pclk and SRCLK need to be the same. I will just rename 1 and adjust the ucf accordingly. But I think what's happening presently is that with a 2MB RAM and 640x480=311040 pixels, the data being written to the videoDACs is overlapping on the display, since my address counter does not have the correct logic to reset to 0 at the end of the last pixel. That's enough memory for 6.7 displays.
Hopefully will have time tonight to try yours and Arlet's suggestions. Thanks!
