It is currently Fri Jun 21, 2024 8:15 pm
PostPosted: Sat Sep 08, 2012 2:41 pm
FRAM for Dummies is offered by Mouser. And guess what? It is free while supplies last!
http://www.mouser.com/framfordummies/
PostPosted: Sat Sep 08, 2012 7:40 pm
Ironically, FRAM is a modern realization of one of the oldest methods of non-volatile data retention.
PostPosted: Sat Sep 08, 2012 8:02 pm
Request placed.
I hired a tech in 1986 who had previously worked on core memories. It was amazing to me how tiny the cores were that he was describing, and that the memory density was much greater than I expected, like 64KB in the space of a 6" cube, IIRC.
In the early 80's it seemed like bubble memory was going to be the next big thing in dense, non-volatile memory, but I guess it never took off. Serial flash today is sure impressive, with tens of gigabytes fitting in a postage-stamp-sized module.
PostPosted: Sun Sep 09, 2012 1:20 am
My first job as a professional hardware engineer and programmer was on the original ZIP Mail Translator (ZMT) installed in U.S. Post Offices over 40 years ago. The ZMT was a sort of von Neumann machine and used an 8K Ferro-Cube core memory...that's 8 kilobits, not kilobytes. Most of it was designed around 74-series logic, but program execution and stored data were in the Ferro-Cube unit. That meant, of course, that shutting down the ZMT didn't required reprogramming when power was restored. That was a good thing, as reloading a program meant running a paper tape through an attached Tele-Type machine, which was a lengthy process, assuming the tape didn't break.
PostPosted: Mon Oct 01, 2012 9:41 pm
I received mine in the mail today.
Users browsing this forum: barnacle and 88 guests
