It is currently Sat Nov 23, 2024 9:48 pm
PostPosted: Thu Aug 09, 2012 8:22 pm
Hackaday posted about this remarkable study: a 256-processor supercomputer using hundreds of thousands of TTL devices.
There's a 300-page pdf which goes into great detail about the design.
It uses many small ROMs as well as 74S381 ALU devices, 74283 adders and 74S182 look-ahead carry generators. It directly supports single-cycle add, subtract and multiply of single-precision floats, and supports multi-step sequences for double-precision operations. So that's a 24x24 multiply in 400 nanoseconds, if I have it right.
PostPosted: Fri Aug 10, 2012 3:30 am
So with all the multiplications and divisions it takes to calculate a trig or log function, a single 20MHz 6502 would still be quite a bit faster (although for 16-bit, not 24-bit) with the look-up tables! :D :D :D :D
PostPosted: Fri Aug 10, 2012 5:26 am
And use far less power to boot! :lol: :lol: :lol: I won't even mention the huge number of person-hours it would have taken to build the monster, fix all the construction errors, determine that it will actually compute, etc.
PostPosted: Fri Aug 10, 2012 6:32 am
Edit: there's an interesting graph and analysis towards the end of reliability of the machine. At 70 degrees the mean time to failure is about a day. At some lower but reasonable temperature it gets up to four days. That's reasonable for a very early experimental machine but seems limiting.
Don't forget you still need to build 256 processors and a routing network.
I think the flaw in the plan is that 24-bit lookup tables would be much larger. But it's a fair point that starting with a 20MHz cycle time is going to help... of course those lookup table memories also need to be fast.
As a practical point, building higher precision arithmetic out of smaller building blocks is the necessary missing step for Garth's approach. (On FPGA a 32x32 multiply is trivial to synthesise, although it might not be single-cycle.) The paper goes into some detail about producing double-precision results given a single-precision primitive.
(Reading further into the paper, the cycle time is a bit shorter than I said, but the full multiply operation including normalisation seems to take 3 cycles)
Edit: overall, it's a good read for a feasibility study and an insight into machine organisation and implementation choices.
Users browsing this forum: No registered users and 52 guests
