It is currently Fri Nov 22, 2024 2:13 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Tue Apr 25, 2000 3:43 pm
I happened to be poking around the 'net looking up info about an old friend, the 6502. I have read most of the 6502-related stuff and find it interesting that, depending on your age, everyone has a different perspective on this.
I got involved in the Apple II in HS (1978). I didn't touch assembler programming until I got in college. I wrote my own assembler for the 6502-chip by writing a full-screen editor (with move subroutines in native machine code - page x'0300') for speed. Then I wrote a BASIC program that would assemble (product object code).
Eventually, after I got the bugs worked out (it took about 5 compiles with each running about 1/2 hour - slow disk times) and then used this assembler (assembled with the BASIC assembler) as my new assembler. Once you get a limited-function assembler, you can then grow your functionality. Kind of incestuous but still pretty neat.
After writing this, I moved some important storage to zero page and what a HUGE difference the 2 machine cyles per access made! Being a Wozniak-phile, I brutalized the code so it was as fast as could be made. It taught me a lot about bit manipulation (which is the final step in becoming a very good assembler coder).
Eventually, I used the RWTS Apple II subroutine to write my own disk directory search and disk read routines (to read a standard ASCII file without the DOS services.
I LOVED the 6502 design; the addressing modes, the accumulator, carry flags, SED, etc. Interestingly, if you ever get a chance to view Wozniak's original monitor, there is a routine called NXTA2 that cryptically sets multiple condition codes while incrementing a 2-byte pointer. What a tour-de-force. Or check out his BASCALC routine for driving the video storage base addresses.
Thanks for listening to this rambling.
Jim Lewandowski
Report this post
