It is currently Sat Nov 23, 2024 11:48 pm
 Post subject: CPU flags
PostPosted: Thu Jul 26, 2012 3:29 am
After lo these many years it finally dawned on me that a zero ("Z") flag is simply the inclusive-OR of all the register bits. Shortly thereafter another revelation: a parity ("P") flag is simply the exclusive-OR of all the register bits.
And then I wondered: did any computer ever have a flag based on the AND of all the register bits? This flag would be set if all the register bits are set, clear otherwise. Interpreted as a signed value: set if minus one, otherwise clear.
In the 65xx-world this would be a handy flag for all those countdown loops with a variable starting index that could be greater than 127. Then the last iteration wouldn't have to be handled as a special case. There are also plenty of occasions where a memory byte is set to $FF as a flag value; with an "M" ("A"? "O"?) flag simply loading the byte into a register would be enough to tell.
A quick Google search didn't turn anything up, but then I really don't have a proper name for what I'm looking for either. The real question I want to research is whether or not such a flag would be useful enough in general to implement. What has been the historical experience, if any? (The parity flag, for instance, has often been implemented but is sometimes questioned as to its usefulness).
 Post subject: Re: CPU flags
PostPosted: Thu Jul 26, 2012 3:54 am
If you want to branch until a value rolls past zero, a decrement which affects the carry flag would also work.
PostPosted: Thu Jul 26, 2012 5:19 am
or BIT, so you don't even have to affect A, X, or Y. There might be a use for an F flag, but it's common to use a byte as a flag and anything but 0 means the flag is set, or at least anything negative. Without an STF (store FF) instruction which I would like to have, setting a flag can be a simple DEC, as long as you don't do it so many times that it again becomes 0 or even just positive. Use STZ to clear it. Then BIT, BMI/BPL for example tests it, without regard for what's in any of the registers, and without affecting them.
INC and DEC don't affect the carry flag.
PostPosted: Thu Jul 26, 2012 6:16 am
Yes. Just to be clear, I was implying that instead of adding both a flag and 2 new branch instructions to the CPU, some of the functionality could be accomplished by adding something like dxc/dyc (decrement X/Y outputting carry), which would probably be a bit cheaper.
PostPosted: Thu Jul 26, 2012 5:20 pm
You could also:
         sec
         ror flag
to set it and:
         bit flag
to test it.
Users browsing this forum: Google [Bot] and 73 guests
