Hi Miles! -- and welcome! Nice to hear about your emulator and assembler. Did you have an actual question? I'm sure someone will be glad to try to answer.
cheers,
Thanks! I've got a lot of questions, indeed, but I really don't want to cause any trouble. So, here are just a few:
1) A simple question just to make sure: is the behaviour of the stack instructions PHA, PLA etc and JSR, RTS the same as on the 6502 (PHA = write value then decrement S, PLA = increment S then read value, JSR = increment PC, write high word, decrement S, write low word, decrement S)?
2) How many cycles do the instructions use (relative in comparison to each other)? Just a rough estimate, so that I can adjust the emulator and watch out for bottlenecks in the program.
3) Is the stack placed at $0001 0000 .. $0001 ffff? The IRQ vectors are found at $ffff fffa etc? Is there an additional COP vector ($ffff fff4) or something similar that can be used for system calls?
4) Does a dev. board exist with an attached video generator? If so, how is it organized and what is the resolution? (So I can perhaps emulate some kind of display output.)
5) Would it be possible to add the instruction 'JSR (zp, x)'? This may seem very odd at first, but there's a reason. When I write larger programs I use object oriented programming a lot. In x86 assembly you would likely use something like 'mov eax, [esi + offset]' for loading an object attribute value. On a 68000 there is 'MOVE.L offset(A5), D0'. Unfortunately an addressing mode like 'LDA (zp), #offset' does not exist, and addressing attributes using 'LDY #offset : LDA (zp), y' would result in very long code. So I decided to place the objects into the zero page, load the X register with the address of the object and use the zp value as the constant offset of the attribute. This will give me 'LDA offset, x' for loading the attribute value of an object pointed to by X. So far so good. The problem is: how do you call an object method? The x86 has 'call [esi + offset]' for this. The 68000 at least got 'JSR offset(A5)' in combination with an additional ' JMP abs.L'. All members of the 6502 family lack a short and quick way to perform this call, although it is really very useful and may speed up programs drastically. Now even a zp as the offset would be enough, as the objects reside in zero page anyway. Hence 'JSR (zp, x)' would be fine. What do you think: would it be possible/make sense to add such an instruction?
6) Are there still plans to include instructions for multiplication and division? (I personally would prefer a simple unsigned 'MUL' that multiplies A * Y with the result in Y (low) and A (high) but that's a matter of taste really.)
Now I could go on endlessly, but I rather not get on your nerves if I haven't done so already. Thanks for your patience.
Miles
