When i run makesim i get this errors:
C:\cc65\sim>echo off
SIM
The system cannot find the path specified.
read.s(58): Error: Illegal addressing mode
write.s(64): Error: Illegal addressing mode
common
conio
dbg
runtime
Build library
ar65.exe: Warning: Library `sim.lib' not found - will be created
ar65.exe: Error: Could not open `common\*.o': No such file or directory
ar65.exe: Error: Could not open `runtime\*.o': No such file or directory
ar65.exe: Error: Could not open `conio\*.o': No such file or directory
ar65.exe: Error: Could not open `dbg\*.o': No such file or directory
Move library files
Cleanup
The system cannot find the file specified.
Press any key to continue . . .
But it kinda still works...
I also modified my sim.cfg and now some routines are missing, and jmp in hello1(the first instruction) points to address 0000.
sim.cfg
# kawalski Simulator
MEMORY {
HEADER: start = $C000, size = $0004, file = %O;
ZP: start = $0000, size = $00D0, type = rw, define = yes;
RAM: start = $0200, size = $7E00, file = %O, define = yes;
ROM: start = $C010, size = $3FE0, type = ro, define = yes;
SEGMENTS {
EXEHDR: load = HEADER, type = ro;
STARTUP: load = ROM, type = ro;
LOWCODE: load = ROM, type = ro, optional = yes;
INIT: load = ROM, type = ro, define = yes, optional = yes;
CODE: load = ROM, type = ro;
RODATA: load = ROM, type = ro;
DATA: load = RAM, type = rw;
BSS: load = RAM, type = bss, define = yes;
HEAP: load = RAM, type = bss, optional = yes; # must sit just below stack
ZEROPAGE: load = ZP, type = zp;
FEATURES {
CONDES: segment = INIT,
type = constructor,
label = __CONSTRUCTOR_TABLE__,
count = __CONSTRUCTOR_COUNT__;
CONDES: segment = RODATA,
type = destructor,
label = __DESTRUCTOR_TABLE__,
count = __DESTRUCTOR_COUNT__;
CONDES: type = interruptor,
segment = RODATA,
label = __INTERRUPTOR_TABLE__,
count = __INTERRUPTOR_COUNT__;
SYMBOLS {
__STACKSIZE__ = $800; # 2K stack
SBC map:
0-32k ram
32k- 48k i/o stuff
48k-64k ram
