It is currently Sun May 19, 2013 5:13 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue May 29, 2012 2:41 pm
cjb wrote:
cjb wrote:
MEM can't be greater than $7F00. The words that scan and add to the dictionary do signed comparisons with pointers.
Hi, cjb. MEM is not listed in my (6502) edition of the Fig glossary
I was referring to the parameter set in the fig-forth assembler source:
MEM       = $6E00               ;top of assigned memory+1 byte.
UAREA     = MEM-128             ;128 bytes of user area
DAREA     = UAREA-BMAG          ;disk buffer space.
I was seeing the same problem as the OP when I had MEM much higher in memory, something that I'd been tracing the problems it caused for 2 straight days-- but then it struck me, and seconds later, everything worked! :D
I looked around and found MEM, it's set to $4000.
It's clearly my U* routine.
You can see from this trace:
0F15             BASE 0976 98 01F4  S:0001 0000 0002
0F17             @ 0785 96 01F4  S:3FA6 0001 0000 0002
0F19             U* 052F 96 01F4  S:000A 0001 0000 0002
0F1B             D+ 06BE 96 01F4  S:0000 0000 0000 0002
0F1D             DPL 097F 9A 01F4  S:0000 0002
The trace output is the IP, the name of the word, the CFA, the stack pointer, and the return stack. After the S: is the contents of the current stack. The gap is spaces in the front represents nesting (in truth this is just a space per byte on the return stack - not a perfect representation of nesting since some words >R and <R, but close enough).
It's just started to convert "123". You can see if found the "1", and converted it to 1 via DIGIT. I'm not sure what the double 0000 0002 is at this point. Then it fetches the BASE (10 is this case) and calls U*. But 0A * 01 is not 00. I guess U* takes two singles, and multiplies then unsigned in to an unsigned double. So, in theory the result should be 0000 000A, but instead it's zero.
However, note right after that D+ appears to work in this case.
So, it's certainly in U* at this point. Unfortunately, binary multiplication is not my strong suit. I haven't sussed out the issue here yet. ROL looks good, unless the flags are wrong. The rest are reasonably proven instructions. All of the work is in memory, rather than in registers, that makes it a little more difficult to trace.
Anyway, more digging.
PostPosted: Tue May 29, 2012 6:01 pm
You can see from this trace [...] After the S: is the contents of the current stack.
It took me a moment to get used to how your stack dump is formatted. Usually when the contents of a Forth stack are portrayed in text, the top-of-stack item shows on the right, not the left. But you're right -- U* is clearly not working, since it multiplied 0Ah by 1 and returned 0 (in double precision).
This wouldn't be caused by the bug Garth mentioned. Most likely it's another artifact of your simulator... probably in the 6502's shift/rotate instructions and their flags settings -- stuff that Forth hardly uses except in math routines. Fun!
http://LaughtonElectronics.com
PostPosted: Wed May 30, 2012 3:42 am
Hazah! Success.
Precedence hates me.
result = result << 1 + carry;
is actually
result = result << (1 + carry);
So, when ROL hits with Carry set, we end up with a 2 for 1 deal -- not good.
Quick fix and 123 123 + . gets me 246 like Chuck intended!
Now, VLIST appears to not be clearing the high bit on the last character... *sigh*...so, more digging.
But progress every day! I love the little errors I stumble upon. The mind -- it's a terrible thing.
PostPosted: Wed May 30, 2012 4:36 am
So I dug a little more. VLIST is pure Forth, and relies on TYPE, but I don't think TYPE does anything about the high bit on the final letter. TYPE itself looks pretty basic. So I guess it's working as designed, but this doesn't seem right to me.
PostPosted: Wed May 30, 2012 5:03 pm
You're a funny guy. Congratulations on your success with Forth and your emulator!
PostPosted: Wed May 30, 2012 5:24 pm
Tell me about it! Each day before I built POC V1.0 I'd review the design, only to find another little goof. Then I finally went ahead and built the thing, only to find yet another gotcha. <Sigh> At least V1.1 worked without the need for blue wire. :P
x86? We ain't got no x86. We don't need no stinking x86!
PostPosted: Thu May 31, 2012 9:31 pm
Dabbling some more, I have a couple of other new issues to tackle.
I can't seem to redefine a word.
I can create an initial word:
: hello ." Hello world!" ;
but if I do it again, I get a ? MSG # 4. I need to dig up what that message means.
Also, apparently my DO - LOOP structures are not working, at least from the compiler since (DO) and (LOOP) work fine from the internal definitions.
I tried adding 3 words in the assembly. 1 took, one or both of the other two sent something in to a spin to where I would get the version message, but that was it -- after that it was stuck.
The word I added was a new USER variable to handle a TRACE flag, and I wrapped the JSR TRACE with some simply logic to check that flag.
Funny thing, when I enabled the trace the output was WILDLY different from when I simply had JSR TRACE hard coded.
So, I'm still in the "simplest things flummox me" stage. Guess I have more gremlins in the core to hunt down, but I think I'm running out of rare instructions to test.
PostPosted: Fri Jun 01, 2012 6:07 pm
It's a warning, not an error. Your new definition was successfully created. MSG#4 means "Not unique" Forth will warn you that the name already exists but it won't stop you from creating a new word by the same name.
Try creating another new word
: hello ." Hello world, VERSION TWO" ;
Then type "hello" and you'll see the new word is found -- not the old word.
PostPosted: Sun Jun 03, 2012 5:08 am
Yea, I finally tracked down the text of the 2 screens with the FIG error messages on it. Kind of annoying they're not in the original FIG listings. I stumbled upon a listing for an old Atari Forth that had them. After poking around, I see they're also in the Users Guide for the PDP-11 Forth (I remember when my friend keyed that in to our PDP-11 at school).
Thanks for the info though.
But, in other news, HAZAH! I found my FORGET bug. It wasn't my CPU at all!
If anything, it was my assembler.
In the FIG listing, all of the ZBRANCH and BRANCH offsets are hard coded constants ("hand crafted"), save for 1, in the core of FORGET.
There's this code:
L3220     .WORD R,OVER,ULESS
          .WORD ZBRAN,L3225-*
          .WORD FORTH,DEFIN,AT,DUP
          .WORD VOCL,STORE
          .WORD BRAN,$FFFF-24+1 ; L3220-*
L3225     .WORD DUP,CLIT
The culprit is that "L3225-*".
In MY assembler, I get a value of 20 ($14), but if you use the eenie-meenie-minie-moe method of counting bytes using the Mark 1 Eyeball and Digitus Indexitus, I count that it should be 18 ($12). So, I guess I'm not advancing the '*' PC at the right point in my assembler. I can honestly say I haven't put any thought whatsoever in to how '*' is handled, specifically in this kind of situation. Arguably I'm doing it "wrong" since here's evidence of "wrongness", but I don't really know. (Does any one know how '*' should behave? Comments welcome...)
For the moment, I worked around it by simply changing it to "L3225-*-2", and HAZAH!, success. Now my FORTH can be as forgetful and I am.
So, that's good. One less thing.
While I'm not willing to stick this thing on a rocket to mars, I'm getting more confident that this beast is actually working. I can start adding mass storage to the emulator and implementing the disk primitives in the Forth. Then I can hunt down the awful Forth line editor to see if I can get that working. Next would be adding, perhaps, ANSI-ish escape handling and keyboard arrows (Forget arrows, WordStar diamond yo!) and such so I can hack out a Forth screen editor for my "smart" terminal.
And then...then...uh...I don't know then. Don't have a then set up for, um, then.
Debugging going back and forth from machine code to high level Forth is a bit of a pain. I added memory read/write breakpoints to the emulator, that helped a lot. Updated my memory dump display, that was handy too. Highlighting differences between display updates was helpful as well.
With the memory read breakpoints, I was able to "single step" high level Forth words by putting a BP on each word in the Parameter Field. I can safely say I'm glad I'm not debugging this on hardware with a 80x25 terminal staring at hex dumps from a machine monitor. (Though I was thinking about adding SuperMon to this...) Mind, if I was doing that I'd likely have a CPU that worked along with an Assembler that worked, but what fun is that?
Anyway, onward...Zoiks, and away!
PostPosted: Mon Jun 04, 2012 1:42 pm
I figured this out, it's not that mysterious as I thought. The problem is that in my assembler, I'm not incrementing my "current address" internal variable for each element of the .WORD and .BYTE instructions, I simply accumulate the delta and realize it at the end. '*' doesn't really need that much deep thought. Mind, I haven't fixed it, but just figured out what it is.
PostPosted: Tue Jun 05, 2012 2:47 am
Looking back a ways...
whartung wrote:
My current problem is basically it's printing "? Msg #0" for pretty much anything I type after I hit enter. Whether its a blank line, a number or a forth word -- always that same thing.
I wrote:
somehow I'm still drawing a blank [...] I searched the assembly source to find code that uses < > and 0< (which do signed comparisons) and once again noticed nothing suspicious. What am I missing?
This story has an odd outcome. If you search the Fig Forth assembly source code as I did, looking for < (the signed less-than test), you'll see it's never used for testing dictionary addresses. And if you look at the code that does test dictionary addresses you'll see it uses U< (the unsigned version). This is as you would expect, since addresses are unsigned values.
However, Fig Forth U< turns out to be buggy. Apparently a hasty, last-minute addition to the code (it's unlisted in the glossary), U< is defined as
: U< - 0< ;
This is incorrect, as explained here. With whartung's assistance a revised version of U< has now been successfully tested, and the original complaint is resolved -- MEM can be set as high as you like.
:oops: Ironically, the U< bug is clearly documented in notes I pencilled into my copy of the Fig source listing a couple of decades ago. As whartung said,
PostPosted: Thu Jun 07, 2012 2:41 pm
Still working getting I/O going. Nothing too exciting going on there, had to deal with simulator GUI stuff and the internal I/O routines are next, and finally the "hardware".
I added ".S" to print the stack, that was some fun spelunking, and I also added that to the assembly listing -- which was fraught with more danger, but seems to be working now as well.
I am curious about VLIST however, because it relies on "ID.", and I see that routine copy the text of the word out in to PAD, clean up the count and then call TYPE. But there's no consideration for clearing the top bit of the last byte. It's simply not there. It's not in the FIG model at all as far as I can tell. I've looked at several FIG listings, and they all do it the same way.
So, I'm wonder if there's an assumption that the ASCII I/O device is simply implicitly stripping the top bit, since ASCII is only a 7-Bit set. Historical software, historical assumptions.
I looked over at eForth, but it doesn't seem to have (easily findable I should say) either VLIST or ID., so I can't compare what they are doing. I did a little work trying to fix mine, but it just makes me want to get the I/O working some more -- would be nice to have error messages :).
Just curious if anyone else saw similar issues with ID. and VLIST.
PostPosted: Thu Jun 07, 2012 2:58 pm
Yes, I seem to recall seeing the VLIST output on screen, with the last character of every word aliased to something other than normal ASCII. I never considered it enough of a problem to dig in and change the behavior, though.
Sorry for not speaking up sooner, since you did mention this in a previous post.
PostPosted: Wed Jun 13, 2012 2:15 am
In the 6502 implementation shown in the FIG-Forth installation manual, masking is done in EMIT (line 3042 of FIGINST.TXT)
ftp://ftp.taygeta.com/pub/Forth/Archive ... IGINST.ZIP
In 8086 FIG-Forth, masking is done in POUT (line 2501 of FORTH.ASM -- same in either archive, hooray for ancient archive formats :))
ftp://ftp.taygeta.com/pub/Forth/Archive/ibm/fig86.lzh
http://www.umich.edu/~archive/msdos/pro ... /fig86.arc
In 8088 FIG-Forth, masking is done in TYPE (line 1907 of FORTH)
ftp://ftp.taygeta.com/pub/Forth/Compile ... th8088.zip
Not sure which implementation of eForth you were looking at, but the last byte of a word name doesn't have bit 7 flipped in any of the eForths implementations I've dealt with or looked at over the years, so they could just use plain old TYPE for that sort of thing.
PostPosted: Wed Jun 13, 2012 11:05 pm
Thanks for this, now that all makes sense. And this is the "elusive" FIG installation manual with these mythical screens the source code references. There's all these comments in the FIG assembly source to screens and words, and I had no idea what they were referring to. The Fig doc I have doesn't have those screens. This doc is much better.
Yea I was just looking at source from the web pages, I didn't know if they did the 7th bit thing or not. But it was a readily available, "look I don't have download more junk to my hard drive", view it on the web kind of spelunking.
