It is currently Fri Nov 08, 2024 10:31 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: 6502 sbc with web
PostPosted: Thu May 03, 2012 9:27 pm
Offtopic:
Did you get tons of unknown traffic, with various ip addresses from all around the world, from Mexico to Russia? It looks to me as if i have some malware on my pc. I tried to kill all the processes, but that didn't stop it, and after i restarted the computer, the unknown traffic kept going, and after a while i got a blue screen as i do from time to time, and i noticed that the problem was in tpcip.sys.
PostPosted: Thu May 03, 2012 9:38 pm
You'll notice I set a filter to see only traffic to/from another machine on my network. So if I do have bad stuff going on, it wouldn't have shown. If you do see bad stuff, it's worth reacting though. I don't have any general advice that's specific and efficient (I have other advice, ranging like this: reinstall, switch to Linux, run malwarebytes or microsoft's Security essentials, microsoft defender offline, boot from a livecd like Linux mint) - here's advice from other victims.
Cheers Ed
PostPosted: Fri May 04, 2012 12:50 am
I installed malwarebytes and started a scan, i also started a scan with ad-aware, now i only have to wait...
As for the ethernet module, the ic had an epoxy layer as an anti reverse engineering protection, but as i sad, it had the epoxy layer. I was curious and i scratched the epoxy with a screwdriver, and the entire layer came off easily... I can now see that the module uses the famous WIZnet chip, witch leaves room for future tinkering, if i ever get boarded with the module, i can just unsolder the mcu, and connect to the WIZnet directly...
PostPosted: Fri May 04, 2012 1:05 am
Since our older son is somewhat of a networking expert, I asked him about your post, and he said there's not enough information there to figure out much. He runs his server and some at the school he works for under Linux though, and those don't have any trouble. He can see the hacking attempts, but they are never successful. Linux never bluescreens either.
PostPosted: Fri May 04, 2012 1:46 am
I have dual boot, for win and Ubuntu, but i use win since i have stuff that won't run on Linux.
I would want to try to port forward the module port, so it can be acceded via internet, and someone might try to send me a data packet... But i heard that port forwarding might me risky, since hackers might use the opened port to hack their way in, i don't now if this is true, and if it safe to open a port in my router...
PostPosted: Sat May 05, 2012 1:49 am
I port forwarded the module, could somebody try to send me a message:
udp protocol
ip: ---.---.---.--- (router crashed, I'll try to turn it on later today...)
port: 50000
You can use the test program that may be found in the manual that i uploaded.
Edit: My router keeps crashing for the last few days...
PostPosted: Sat May 05, 2012 3:55 am
What kind of router do you have that it keeps crashing? :cry:
PostPosted: Sat May 05, 2012 4:00 am
No Window$ servers here either. We have two 32 bit UNIX boxes (one which contains all the source code for my POC unit's BIOS) and one SuSE 64 bit Linux unit, the latter which hosts E-mail and web services, and acts as the router/gateway for the Internet. All three are as stable as the Rock of Gibraltar, and nearly as bullet-proof. :)
PostPosted: Sat May 05, 2012 3:32 pm
I have a Thomson TG782i , the technician just left, he brought me a new one. He also took the analog splitter away, now my phone line goes over voip, and next time when the router crashes, i won't be able to use my telephone...
Anyway, try sending me the message now:
UDP
IP: 78.1.160.228 (expired)
port: 50000
Edit: If you are using the program that i uploaded(in the manual), first select udp mode on the left side, click connect, after that a new input box will appear with a ip, input my ip there, and the port number. After that write a message in the box below and click send.
PostPosted: Sat May 05, 2012 3:45 pm
Sent you a few packets
PostPosted: Sat May 05, 2012 6:56 pm
4:45pm hello dajgoro
                    4:46pm hello dajgoro
                                                            4:47pm hello dajgoro
                                       4:48pm hello dajgoro
                                       4:49pm hello dajgoro
                                                           4:50pm hello dajgoro
                   4.57 hello dajgoro
                                     17:42 hello dajgoro
                                                        17:42 hello dajgoro
        17:43 hello dajgoro
              17:43 hello dajgoro
                                 18:31 hello dajgoro
                                                    18:31 hello dajgoro
Got them.
Thanks, it's working!
PostPosted: Sat May 05, 2012 7:18 pm
yep, 20 packets sent. The thing with UDP is that packets can be dropped, duplicated or received out of order. On a home network you'll probably be OK, but over the internet it could get interesting.
PostPosted: Sun May 06, 2012 4:41 pm
OffTopic: About the weird packets, Malwarebytes keeps blocking them, but again, the source is unknown, and a full scan didn't help... Any other software that might help exterminate this malware bot?
PostPosted: Sun May 06, 2012 4:49 pm
See my earlier post for some exhaustive cleanup procedures ("advice from other victims")
PostPosted: Sun May 06, 2012 5:09 pm
I guess i will have to try to install them all, and see which will find this malware...
