It is currently Fri Nov 22, 2024 9:56 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: CRTC core
PostPosted: Sun Apr 15, 2012 7:00 pm
Ah - I just got it to go in, which means we get a meaningful report:
Macrocells     Product Terms    Function Block   Registers      Pins
Used/Tot       Used/Tot         Inps Used/Tot    Used/Tot       Used/Tot
108/108 (100%) 291 /540  ( 54%) 211/216 ( 98%)   49 /108 ( 45%) 66 /69  ( 96%)
** Function Block Resources **
Function    Mcells      FB Inps     Signals     Pterms      IO
Block       Used/Tot    Used/Tot    Used        Used/Tot    Used/Tot
FB1          18/18*      36/36*      38          52/90       9/12
FB2          18/18*      34/36       34          39/90      12/12*
FB3          18/18*      34/36       42          45/90       0/12
FB4          18/18*      35/36       35          46/90      11/11*
FB5          18/18*      36/36*      36          54/90       2/11
FB6          18/18*      36/36*      38          55/90       9/11
            108/108     211/216                 291/540     43/69
The trick was to reduce only the product term limit... except now even that seems unnecessary, so the changes to synthesis tactics must have helped and I must have previously not got any advantage from them. Still, the conclusion is the same: it's a tight fit.
PostPosted: Sun Apr 15, 2012 8:17 pm
Dajgoro wrote:
Any suggestions where to find the 95108 in plcc?
I just found this multi-vendor search
http://www.findchips.com/avail?part=Xc95108
Although probably your best bet in general is to have your own curated list of (relatively) local parts distributors who do small quantities with reasonable postage charges.
