It is currently Wed May 22, 2013 5:08 am
PostPosted: Wed Jan 18, 2012 10:11 pm
Hi.
After 14 years, I thought it was time I gave the Micro UK101 a re-visit and a refresh.
I have updated the circuit slightly to make the chip selects based purely on address lines, and OE and WR more conventional, using Phi2 and the R/W. The E select on the 6850 is also now utilised, so follows "conventional" connections.
Also added the memory map to allow you to see the reasoning behind the decode logic.
I have also taken on board all comments in this forum, and updated the MAX232 and clock generator circuits with what you have said - I DO listen :)
The layouts and circuit has been re-visited and quite a bit of work done to improve the images - they are also now in colour (I can use Visio better than I could 14 years ago!).
The URL of the page is unchanged...
http://home.micros.users.btopenworld.com/uk101/uk101.html
Please refresh the page in your browser to make sure you see the latest version - it will show last update of 18th January 2012 near the top.
Regards.
Grant
PostPosted: Thu Jan 19, 2012 10:43 am
Great work!
PostPosted: Thu Jan 19, 2012 8:01 pm
Nice one, Grant!
PostPosted: Thu Jan 19, 2012 10:05 pm
Thanks for your comments. I will be updating my board with the changes to make sure it works, but if anyone can spot any errors with what I have done, please feel free to let me know.
Regards.
Grant
PostPosted: Sun Jan 22, 2012 7:42 pm
Hi.
I am pleased to say that the Micro UK101 page has now been "officially" re-launched :-)
I have done further updates to all diagrams (hope you like them).
I have also changed the clock to use a 4MHz crystal instead of 8MHz, and the first divider is replaced with a cheaper / common 74LS74.
To make sure the information that I have provided is correct, I have totally re-built the Micro UK101 using only the information that I have published (following the wiring diagrams exactly) and it worked first time.
Please refresh your browser to make sure you can see the new page and diagrams (will show "Last update: 22nd January 2012" near the top).
Regards.
Grant.
PostPosted: Mon Jan 23, 2012 1:19 pm
That's a real nice collection of computers you've got there!
