As I wrestle just abit with indexing issues (my brain slowly flexes into software mode...), converting my original code from 8bit data - 16bit address to 16bit data - 32bit addresses, it occurs to me why some people here on this forum are keen on a contiguous 32bit structure , i.e. 32bit data
and address buses. There would be no need for indirect indexed mode, which while an asset for limited 8-bit machines, maybe also an asset for 16-bit machines, but unnecessary for 32-bit machines (assuming 4GB is enough addressable memory?).
I cannot pursue this right now, however I would like to pursue this 65Org32 Core in due course, based on BigEd's original mod of Arlet's NMOS 6502 Core, the mod's for 32bit operation should not be too difficult.
The reset/IRQ/NMI vectors would have to be adjusted for the 32bit structure
optimally. Also, the upper 32bits of the 64bit address lines would have to be truncated, as there is no need for 2^64 memory
yet. Also, eliminating all indirect indexed mode opcodes may actually speed up top speed of a 65Org32 Core...
In a software routine to plot pixels, if a 32-bit index register could be directly transferred to a 32-bit memory location, especially with a max of 4GB worth of pixels, I can see the value in it, most definately. This would cover a large resolution when sending "bytes" to a display of the sort I am working on currently.
Also, I am trying to find a thread where kc5tja had posted his thoughts about extending the 6502 architecture, and very astutely pointed out that for 16bit byte and 32bit bytes the 6502extended CPUs would waste a certain percentage of bits during translation... Still trying to find the link to that thread.
In the mean time, this in another interesting
thread.
