It is currently Sun Oct 06, 2024 3:30 am
 Post subject: Chip marking query
PostPosted: Tue Oct 25, 2011 1:53 pm
Y'all,
What would the difference be between a R6532 and and R6532-II?
 Post subject: Re: Chip marking query
PostPosted: Wed Oct 26, 2011 12:50 am
BillO wrote:
Y'all,
You should check the manufacturer's datasheet.
Toshi
PostPosted: Wed Oct 26, 2011 1:20 am
Well, I tried, but I cannot find a datasheet that mentions the -II variation.
Date codes ate in the mid 80's, but I cannot find a Rockwell datasheet from that era.
PostPosted: Wed Oct 26, 2011 2:53 am
I have a 1984 Rockwell data sheet for 6500 CPUs -- not for the 6532 RIOT, but you might expect similar numbering schemes.
This sheet details the parts numbers as:
  • R65Cxx (eg, xx=02), appended with
  • C or P (ceramic or plastic), appended with
  • 1, 2, 3 or 4 (1 MHz, 2Mhz etc), appended with
  • E or blank (E for extended temperature range)
A 1993 Rockwell CPU datasheet lists:
  • R65xx (eg, xx=02), appended with
  • A or blank (A = 2Mhz, blank = 1MHz), appended with
Not much help there, I'm afraid, unless the "II" at the end of your part number is really a "P1" that has gotten defaced. What's the situation you're dealing with? You have a surplus 6532, and wanna know what you can build with it? Or perhaps you need to replace a 6532 from an existing product...?
PS- the 1993 sheet is for the NMOS product line, which I guess explains the limited frequency range.
PostPosted: Wed Oct 26, 2011 3:49 am
Thanks Jeff,
No, It's definitely a -II. And I have 10 of them. There are 2 part numbers on each chip.
R6532P
R6532-II
I have never seen this before, but apparently Rockwell thought it was of some importance.
I'll eventually build a test circuit and can see if this designation has something o do with clock speed, but other than that I can't think of what I might test for.
PostPosted: Wed Oct 26, 2011 4:11 am
The "II" is not in my 1987 Rockwell data book either. I would guess it's the equivalent of -2 meaning 2MHz.
PostPosted: Wed Oct 26, 2011 4:12 am
R6532P
R6532-II
So, we have one number we understand and one that we don't. My hunch is that those are 1MHz parts, but I admit the "-II" notation remains a mystery. BTW I discovered there's a 6532 entry on Wikipedia. It includes a link to a 1987 Rockwell data sheet. It indicates R6532P is 1 MHz.
The Wikipedia entry says 6532s were used in certain games, so maybe you could flog yours on E-Bay or something. It's not a chip I'd wanna design a project around; I'd rather have a speedy CMOS 65C22. But you may feel differently about that, especially since 6522s have no RAM, and would require a cash outlay.
PostPosted: Wed Oct 26, 2011 4:26 am
BillO wrote:
Y'all,
No idea here as well. I've never seen it before.
PostPosted: Wed Oct 26, 2011 9:12 am
I've seen chips with this sort of marking before, with a normal, recognisable marking matching the data sheet and a second, similar but unrecognised part number. Every time, the recognisable number is the one to go by. In your case, this would be R6532P, indicating a 1MHz part in a plastic package. I've never found out exactly what the second number is - I've cynically thought it's simply there to cause confusion!
It may be the R6532-II is a part number used by whoever Rockwell supplied the chips to. 6532 devices used in Atari VCS consoles were sometimes marked with an Atari part number instead of the manufacturer's part number for example.
Shift to the left,
Shift to the right,
Mask in, Mask Out,
BYTE! BYTE! BYTE!
PostPosted: Wed Oct 26, 2011 11:43 am
I checked my riot chip, and i found this strange thing too, but on mine it is a bit different:
C010750-12
R6532-15
MEXICO J
5565 the logo is located here
8439 the logo is located here
