It is currently Sun Oct 06, 2024 3:11 am
PostPosted: Thu Sep 08, 2011 1:06 am
Hello!
Since i am building my 6502 based sbc project, i have to know at which address is what... So when i want to test some new installed hardware i need to calculate its address, which is sometimes annoying, so i decided to make a small application for address calculation.
Here is my program, it is free and with source.
http://www.iteracija.com/mupload/MMAG.zip
It requires Net Framework 2.0 to run.
You can edit by doubleclicking on the fields.
If you see any bugs let me know.
Feel free to upgrade or modify and share the source code!
Example preview (from my project)
PostPosted: Thu Sep 08, 2011 2:23 pm
SWEET
PostPosted: Sat Sep 10, 2011 1:24 am
Any comments? Has anybody tried it?
PostPosted: Sat Sep 10, 2011 2:04 am
I'm not sure I understand what the program does.
PostPosted: Sat Sep 10, 2011 2:09 pm
Well, you input all your memory and i\o hardware, and the programs tells you which hardware has which address.
PostPosted: Sun Sep 11, 2011 2:11 pm
download is dead :(
PostPosted: Sun Sep 11, 2011 4:30 pm
I hope that's just temporary or an admin mistake. It's good to see projects with source code - and even if there's very little visible feedback, over time there's a good chance some people will come across it by searching and will find it useful and informative.
Ours is the kind of interest where things don't happen very fast, and there are not huge numbers of people coming to visit each new project. It's good to share, but mostly one is doing it for one's own satisfaction.
PostPosted: Sun Sep 11, 2011 4:46 pm
Dajgoro
Something is messed up with your link /site, get the following error when clicking on it : (or even just "http://www.iteracija.com/")
Mike
Warning: mysql_connect() [function.mysql-connect]: Access denied for user 'iteracij'@'localhost' (using password: YES) in /home/iteracij/public_html/iteracija/includes/database.php on line 3
Warning: mysql_select_db() [function.mysql-select-db]: Access denied for user 'iteracij'@'localhost' (using password: NO) in /home/iteracij/public_html/iteracija/includes/database.php on line 4
Warning: mysql_select_db() [function.mysql-select-db]: A link to the server could not be established in /home/iteracij/public_html/iteracija/includes/database.php on line 4
Konekcija na server neuspjela!
Warning: mysql_query() [function.mysql-query]: Access denied for user 'iteracij'@'localhost' (using password: NO) in /home/iteracij/public_html/iteracija/includes/functions.php on line 3
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in /home/iteracij/public_html/iteracija/includes/functions.php on line 3
PostPosted: Tue Sep 13, 2011 2:21 am
I will fix it soon, we had some problems with the hosting...
PostPosted: Thu Sep 15, 2011 11:11 pm
The hosting is now fixed, and now i fixed the files!
Any more questions about the program?
PostPosted: Fri Sep 16, 2011 4:48 pm
Seems to work as indicated. If I get time, I'll apply it to my next 6502 project to see if it is useful. I usually do my memory map first. That won't be until December though.
One thing would be nice though, and that is to allow side-wise expansion. Most of the last few projects I did have memory mapping into a window. Kind of like early PC/DOS architecture. It would be nice if it could accommodate that.
Example
Fixed RAM............0000-7FFF
Mapped Ram.........8000-BFFF.......Block 00..........M00000-M03FFF
..............................................Block 01..........M04000-M07FFF
..............................................Block 02...
..............................................Block 63..........MFC000-MFFFFF
I/O......................C000-CFFF
ROM.....................D000-DFFF
PostPosted: Tue Sep 27, 2011 4:01 pm
For now you can make a ram, and set its size to 0 bytes, and then do all the blocks.
