It is currently Sat Nov 23, 2024 12:13 pm
PostPosted: Sun Sep 14, 2003 1:31 pm
Hi!
I have a processor RP65C02G made by RICOH. I'm looking for a datasheet of this chip. I wonder how much may I overclock this chip. It works fine at 2MHz, but I need more. i.e. 6 MHz. What do you think?
Greetings.
PostPosted: Sun Sep 14, 2003 3:22 pm
You won't damage it by trying, so go ahead and experiment. When you reach a speed that makes it begin crashing once in awhile (most likely) or showing some kind of strange behavior without crashing (less likely), back the speed down perhaps 30%, and consider that the maximum. If it's actually marked for 2MHz, I'm sure it won't reach nearly 6MHz; but it will go the fastest with fast memory and short overall propagation delays of glue logic so the processor's external timing margins are met more easily.
Garth
PostPosted: Sun Sep 14, 2003 4:31 pm
OK. Thanks. I'll try to do it carefully. Than I'll write about success or...
Greetings.
PostPosted: Sun Mar 14, 2004 12:28 am
Well, this circuit works pretty good in 4MHz clock.
I have another problem. Now I'm looking for a datasheet of this circuit. Original datasheet from Ricoh. Maybe someone can help me?
Cheers.
PostPosted: Sun Mar 14, 2004 11:03 pm
Have you tried asking Ricoh? It's worth a shot.
I emailed them once about the RP2A03G CPU (6502-compatible in the NES), and they replied that it's an "ASIC product of Nintendo" and I've have to ask them. Maybe you'll have better luck.
Users browsing this forum: Google [Bot] and 22 guests
