It is currently Thu Sep 26, 2024 10:12 pm
 Post subject: Chip compatibility
PostPosted: Tue Mar 09, 2004 10:30 am
I acquired an R6502P and two R6522Ps from e-bay to have a go at building Daryls SBC. Are these chips compatible?
Any suggestions for a good electronics supplier for the other components?
Andrew Jacobs
PostPosted: Tue Mar 09, 2004 1:19 pm
They should be as long as you set the jumpers correctly around the CPU; I'm using a 65C02 from WDC and an R65C22P2 without any apparent problems.
The TTL is bog-standard; mine was from the scrap box but was sourced from places like Rapid Electronics or Farnell. I had problems getting hold of the 6551 UART but I can probably help (contact me 'off-list'). I have access to an EPROM programmer (but no eraser!) so if you can supply a clean EPROM then I'll zap it for you.
Most of my stuff comes from either Farnell or Rapid Electronics (good for their 'packs' of capacitors and resistors but usual disclaimer!).
Simon
