ElEctric_EyE wrote:
It does convert without using decimal mode?...
Yes, that's correct. Decimal mode is not used.
I notice, I think, that Bruce cut off the output just before the point where the algorithm needs an extra wrinkle. Which is only fair - he had a deadline!
Actually, I finished this quite a while ago. With a division routine that uses an 8-bit denominator, you can only get 7 more digits before the denominator (of the first call to DIV) exceeds 8 bits. I wrote a version that buffers the previous digit (with 8 bits, you don't reach the point where you need to count nines), and it's a little longer, but not much. (Counting nines is longer still, but not a lot.) Since there wasn't much difference between the two versions, I chose the shortest one to (hopefully) encourage as many people as possible to try it.
There's a (somewhat mathematical) paper here explaining the algorithm - which also gives us a clue as to how far we can get with 8-bit bytes, and how much further we might get with 16-bit bytes. The mul and div routines would need some 8-counts adjusting to 16, at least.
A 65org16 version (which would have a 32-bit intermediate result -- a 24-bit is sufficient -- and "P" would be an array of 16-bit values rather than 8-bit values) with buffering and counting can generate over 250 times as much output as an 8-bit version (and over 300 times as much as the above). Or, as you suggested, you could just change the LDY #8 to LDY #16 in MUL and DIV and be done with it.
RichTW wrote:
And there was me thinking that it must use some previously unknown secret feature of the 6502 that made it start doing arithmetic in base pi
2.222... = pi in base pi/(pi-2) (=~ 2.752) not base pi.
