It is currently Sat Nov 23, 2024 1:22 am
PostPosted: Thu Mar 04, 2004 11:55 am
hi,
i have problem with the indirect indexed adressing on a zero-page.
like i understood my documentation, the following code should work, but it don't. my problem is that i never get the value of the TAB_VEC.
what did i wrong?
i'm using the "6502 Macroassembler & Simulator" from Michal Kowalski.
in the first listfield contains the number of values to check. the routine checks if values are even or odd. if even, x-register gets increment. at the end, the value of the x-register is pushed on the stack.
.ORG $00
CLD
LDY #0
LDA (TAB_VEC),Y
TAY
LDX #0
LOOP CLC
LDA (TAB_VEC),Y
ROR
BCS NO_COUNT
INX
NO_COUNT: DEY
BNE LOOP
TXA
PHA
.ORG $50
TAB_VEC: .byte 8
.byte 1
.byte 2
.byte 3
.byte 4
.byte 5
.byte 6
.byte 7
.byte 8
RTS
thx for help, ai295
PostPosted: Thu Mar 04, 2004 12:53 pm
In indirect indexed addressing the memory location in the instruction (e.g. TAB_VEC in your code) must be a zero page location where a 16 bit address is stored. The processor reads this address and adds the Y register to it to identify the actual address of the data to be accessed.
In your code TAB_VEC assembles to be the address of the start of your data table rather than the address of a zero page pointer to the data. In fact if you had written LDA TAB_VEC,Y (e.g. indexed addressing) then it would have worked.
I've adjusted to the code to make it use indirect indexed addressing and indicated a couple of other small things (like not putting the program itself on zero page). Here is the reworked source.
    .ORG $00
; TAB_VEC will be a 16 bit pointer to where the data actually
; is held
TAB_VEC .DS 2
; We'll move the code to a more reasonable starting address
    .ORG $200
    .START $200
    LDA #<DATA  ;Point TAB_VEC at the test data
    LDX #>DATA
    STA TAB_VEC+0
    STX TAB_VEC+1
    CLD
    LDY #0
    LDA (TAB_VEC),Y
    TAY
    LDX #0
LOOP    CLC         ;<-- Not necessary ROR will set/clear C
    LDA (TAB_VEC),Y
    ROR
    BCS NO_COUNT
    INX
NO_COUNT:
    DEY
    BNE LOOP
    TXA         ;Leave result in A
    ;PHA
    BRK     ;Stop the emulator
; Place the test data somewhere else in the memory
    .ORG $500
DATA:   .byte 8
    .byte 1
    .byte 2
    .byte 3
    .byte 4
    .byte 5
    .byte 6
    .byte 7
    .byte 8
Andrew Jacobs
