It is currently Wed Nov 13, 2024 5:49 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jun 18, 2011 2:46 pm
paul_nicholls wrote:
Speaking of which, does any here know how to set the c64 text mode to upper-case only, or both lower/upper case?
I think there are some key combinations on the C64 you can use, but you can also use
         print chr$(14)
resp.
         print chr$(142)
to switch between upper/lower and graphics/uppercase characters
André
PostPosted: Sat Jun 18, 2011 10:56 pm
Thanks André :)
After doing some googling I found this:
http://en.wikipedia.org/wiki/PETSCII
PETSCII provides for shifting between the power-on default (unshifted) uppercase+graphics character set and the alternative (shifted) lower+uppercase set (where the shifted set contains a subset of the block graphic characters of the unshifted set). The shift between modes is done by POKEing location 59468 with the value 14 to select the alternative set or 12 to revert to standard. On C64 the sets are alternated by flipping bit 2 of the byte 53272.
I am going to try the bit flipping (or just set/clear) to see if this works for me :)
cheers,
Paul
"The plastic veneer of civilization is easily melted in the heat of the moment" - Paul Nicholls
PostPosted: Sun Jun 19, 2011 4:42 am
I might look up the PETSCII codes and see if I can maybe convert upper-case chars to PETSCII shifted versions, and lowercase characters to normal upper-case characters as I am doing now :)
I can give you some simple code that can map between PETSCII and ASCII. Use it all the time to drive standard printers from C= hardware.
PostPosted: Sun Jun 19, 2011 4:45 am
Thanks André :)
cheers,
Paul
Printing the characters that André mentioned is less work than twiddling bits. Don't forget that the entire screen will change state when you switch character sets. The C-64, unlike the C-128 in 80 column mode, cannot display from both char sets at the same time.
PostPosted: Sun Jun 19, 2011 7:28 am
Cool! Thanks mate, that would be very handy :)
cheers,
Paul
PostPosted: Mon Jun 20, 2011 9:52 am
@BigDumbDinosaur, I found online some lookup tables that can be used to convert ASCII <--> PETSCII
const
  cASCIIToPETSCIITable: array[0..256 - 1] of Byte = (
    $00,$01,$02,$03,$04,$05,$06,$07,$14,$20,$0d,$11,$93,$0a,$0e,$0f,
    $10,$0b,$12,$13,$08,$15,$16,$17,$18,$19,$1a,$1b,$1c,$1d,$1e,$1f,
    $20,$21,$22,$23,$24,$25,$26,$27,$28,$29,$2a,$2b,$2c,$2d,$2e,$2f,
    $30,$31,$32,$33,$34,$35,$36,$37,$38,$39,$3a,$3b,$3c,$3d,$3e,$3f,
    $40,$c1,$c2,$c3,$c4,$c5,$c6,$c7,$c8,$c9,$ca,$cb,$cc,$cd,$ce,$cf,
    $d0,$d1,$d2,$d3,$d4,$d5,$d6,$d7,$d8,$d9,$da,$5b,$5c,$5d,$5e,$5f,
    $c0,$41,$42,$43,$44,$45,$46,$47,$48,$49,$4a,$4b,$4c,$4d,$4e,$4f,
    $50,$51,$52,$53,$54,$55,$56,$57,$58,$59,$5a,$db,$dc,$dd,$de,$df,
    $80,$81,$82,$83,$84,$85,$86,$87,$88,$89,$8a,$8b,$8c,$8d,$8e,$8f,
    $90,$91,$92,$0c,$94,$95,$96,$97,$98,$99,$9a,$9b,$9c,$9d,$9e,$9f,
    $a0,$a1,$a2,$a3,$a4,$a5,$a6,$a7,$a8,$a9,$aa,$ab,$ac,$ad,$ae,$af,
    $b0,$b1,$b2,$b3,$b4,$b5,$b6,$b7,$b8,$b9,$ba,$bb,$bc,$bd,$be,$bf,
    $60,$61,$62,$63,$64,$65,$66,$67,$68,$69,$6a,$6b,$6c,$6d,$6e,$6f,
    $70,$71,$72,$73,$74,$75,$76,$77,$78,$79,$7a,$7b,$7c,$7d,$7e,$7f,
    $e0,$e1,$e2,$e3,$e4,$e5,$e6,$e7,$e8,$e9,$ea,$eb,$ec,$ed,$ee,$ef,
    $f0,$f1,$f2,$f3,$f4,$f5,$f6,$f7,$f8,$f9,$fa,$fb,$fc,$fd,$fe,$ff
  cPETSCIIToASCIITable: array[0..256 - 1] of Byte = (
    $00,$01,$02,$03,$04,$05,$06,$07,$14,$09,$0d,$11,$93,$0a,$0e,$0f,
    $40,$61,$62,$63,$64,$65,$66,$67,$68,$69,$6a,$6b,$6c,$6d,$6e,$6f,
    $70,$71,$72,$73,$74,$75,$76,$77,$78,$79,$7a,$5b,$5c,$5d,$5e,$5f,
    $c0,$c1,$c2,$c3,$c4,$c5,$c6,$c7,$c8,$c9,$ca,$cb,$cc,$cd,$ce,$cf,
    $d0,$d1,$d2,$d3,$d4,$d5,$d6,$d7,$d8,$d9,$da,$db,$dc,$dd,$de,$df,
    $60,$41,$42,$43,$44,$45,$46,$47,$48,$49,$4a,$4b,$4c,$4d,$4e,$4f,
    $50,$51,$52,$53,$54,$55,$56,$57,$58,$59,$5a,$7b,$7c,$7d,$7e,$7f,
I have converted it from C to Pascal, but it should be easily converted to other languages, or even Assembly :)
I got them from here:
http://codebase64.org/doku.php?id=source_conversion
See Petcom (petcom.c)
cheers,
Paul
PostPosted: Mon Jun 20, 2011 5:32 pm
cheers,
Paul
I couldn't seem to find the file in which I have PETSCII to ASCII conversion. It may be off-line on an archive tape (which I don't store here), so I'll have to do some digging.
Meanwhile, here's code that takes a PETSCII character and converts it to a CBM screen code.
;CONVERT CBM PETSCII to SCREEN CODE
;   .A = PETSCII character
;   .A = screen code
;   .X = entry value
;   .Y = entry value
;   Conversion rules:
;   PETSCII Range      Input          Output      Mask
;   Low Control      $00 - $1F ---> $00 - $1F
;   Punc & Numerals  $20 - $3F ---> $20 - $3F   00111111
;   Alpha LC         $40 - $5F ---> $00 - $1F   00111111
;   Alt Alpha LC     $60 - $7F ---> $40 - $5F   01011111
;   High Control     $80 - $9F ---> $80 - $9F
;   Alpha UC         $C0 - $FE ---> $40 - $FE   01111111
;   Pi               $FF ---------> $5E
petcodcl =$1f                  ;low PETSCII control range end
petcodch =$9f                  ;high PETSCII control range end
petcodl  =$60                  ;regular LC PETSCII range end
petcodm  =$80                  ;alternate LC PETSCII range end
petcodp  =$7f                  ;pi PETSCII test value
petcodps =$5e                  ;pi screen code
pschmask =%01111111            ;PETSCII to screen code high-range
psclmask =%10111111            ;PETSCII to screen code mid-range
pscmmask =%11011111            ;PETSCII to screen code low-range
scblank  =$20                  ;blank char screen code
petscode cmp #petcodcl+1       ;low control code end
         bcc petcod03          ;skip conversion
         cmp #petcodl          ;regular LC range end
         bcs petcod01          ;try next
         and #psclmask         ;change to LC screen code
         rts                   ;done
petcod01 cmp #petcodm          ;alternate LC range
         bcs petcod02          ;UC range or pi
         and #pscmmask
         rts
petcod02 cmp #petcodch+1       ;high control code end
         bcc petcod03          ;no conversion
         and #pschmask
         cmp #petcodp          ;is it pi?
         bne petcod03          ;no, so return it unchanged
         lda #petcodps         ;pi screen code
petcod03 rts
PostPosted: Mon Jun 20, 2011 8:44 pm
Thanks mate, that should come in really handy for when I want to do a TextOut(x,y,text) function in my compiler :)
cheers,
Paul
PostPosted: Tue Jun 21, 2011 6:51 am
I haven't tested it, but I have now made a look up table for PETSCII -> CBM Screen Codes similar to the other ones I did:
  cPETSCIIToCBMScreenCode: array [0..256 - 1] of Byte = (
    $90,$91,$92,$93,$94,$95,$96,$97,$98,$99,$9a,$9b,$9c,$9d,$9e,$9f,
    $00,$01,$02,$03,$04,$05,$06,$07,$08,$09,$0a,$0b,$0c,$0d,$0e,$0f,
    $10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$1a,$1b,$1c,$1d,$1e,$1f,
    $40,$41,$42,$43,$44,$45,$46,$47,$48,$49,$4a,$4b,$4c,$4d,$4e,$4f,
    $50,$51,$52,$53,$54,$55,$56,$57,$58,$59,$5a,$5b,$5c,$5d,$5e,$5f,
    $70,$71,$72,$73,$74,$75,$76,$77,$78,$79,$7a,$7b,$7c,$7d,$7e,$5e
I used this info here:
http://sta.c64.org/cbm64pettoscr.html
Maybe someone will find this useful.
cheers,
Paul
Users browsing this forum: Google [Bot] and 20 guests
