It is currently Mon Oct 07, 2024 1:28 am
PostPosted: Sun Apr 24, 2011 5:13 am
Hello there. I'm new to the forums, and I have a question for 6502 DIY computer veterans.
It's my intention to construct a homebrew 65xx based computer and have purchased a DATEL EPROMMER 64 in order to burn ROMs. I thought the device supported 27xxx series EPROMS -only-. To my surprise, the software has an "ERASE E-EPROMS" option, which I take to mean it can handle 28xxx series EEPROMS, too.
Is this correct? Would an EEPROM equivalent to the 27C128 be the 28C128?
Joe Cassara
PostPosted: Sun Apr 24, 2011 11:23 am
First, welcome to the forums!...
Instead of a 28C128, equivalent 128Kx8 EEPROMS that I found are made by a company called Atmel. They're the 28C010, see if your programmer supports those. I looked them up on Digikey, and they were ~$35US each!?!
Instead of looking for EEPROMS, maybe you should look for FLASH. They are basically the same.
I found a 5Volt 128Kx8 SST39SF010A-70-4C-PHE Flash for $1.87, and it's a 32-pin DIP.
Go to an electronics sight like DigiKey or Mouser or Newark, and type in some parts from your programmer's compatibility list. That's a great way to get a feel for what it can do.
PostPosted: Sun Apr 24, 2011 12:52 pm
I think the Datel Eprommer 64 is a device to plug into the C64 (user or expansion port). Don't think it burns devices larger than 32k (or maybe 64k), or any of the Flash devices
André
PostPosted: Sun Apr 24, 2011 2:59 pm
André
Oh jeez. I overlooked the fact those 27C128 are 16Kx8, 128Kbits. Won't find any of those, except maybe on ebay.
Someone over on the Commodore 64 forums may be able to help.
PostPosted: Sun Apr 24, 2011 3:50 pm
Andre, you're correct. It's a C64 user port EPROM programmer. BTW, last I looked, Jameco still listed 27C128s.
