; insertion sort of (up to) 256 8 bit elements
; orders them lowest to highest, bottom to top
; the list must be page aligned
; list = address of first element
; top = location containing the location in the
; page of the top of the list = number of
; elements - 1 (list is page aligned, zero
; based, first element is 0)
; save_y = location to save where we are in the
; list while we insert an out of place
; element
; starts at the top of the list and scans downward
; looking for an out of place element ie a larger
; element under a smaller element. when we
; find one out of place we save it's location,
; stash it in X and scan upward bumping elements
; down as we go till we find where the current
; element goes ie till we either find an element >=
; to the the one we want to insert or untill we reach
; the top of the list. Then we go back to scanning
; downward for out of place elements picking up
; where we left off at the saved location
INSERTION_SORT
ldy top
beq DONE ; if the last is the first it's already sorted
bne ENTER_NEXT
INSERT
sty save_y ; remember where we were while we insert
ldx list,y ; get the current element out of the way in X
FIND_LOOP
lda list+1,y ; bump one down
sta list,y
iny
cpy top ; are we at the top of the list?
beq PLACE ; if yes, then go put current element in place
txa ; else get the current element in to A
cmp list+1,y ; to compare
beq PLACE2 ; if = this is the place and the current
; element is already in A
bcs FIND_LOOP ; if the current element is > go bump another
; down
PLACE
txa ; get the current element in to A to place it
PLACE2 ; come here to place it if it's already in A
sta list,y
ldy save_y ; pick up scanning down where we left off
beq DONE ; if we're at bottom we're done
dey
NEXT
lda list+1,y
cmp list,y ; if the current element > the one above
bcc INSERT ; go insert it in the right place
ENTER_NEXT
dey
bne NEXT
lda list+1,y
cmp list,y ; still need to check the bottom element
bcc INSERT
DONE
rts
