Arlet wrote:
Maybe I'm not understanding the schematics properly, but it looks like your $C004 location is write-only, so the INC instruction wouldn't work.
Those are old/incorrect schematics. I could've corrected them, but decided against that. I'll post updated ones when I get this working. I shouldn't have posted any schematics at all until I was sure it was working...
Speaking of schematics, now when I think I have a solid design, I like to re-input the whole project from scratch as proof for myself. I like to create a new project, copy the schematic files(.sch) and the 6502 core verilog files(.v) then remake the symbols. Then open up the top-level schematic and update the symbols. For the RAM & ROM I copy nothing, I remake those from scratch, which isn't too difficult... But I digress!
Right now I have each output of the 2 FD8CE FF's going to a 2to1 MUX that selects a '0' when inactive or 'data' when active. The output of each MUX goes to 8 wide(9-inputs) OR gates before going to the 6502 Data In. Heh, schematic entry has a symbol that has 16 inputs!, but 8 of them would not fit neatly on 1 max'd out schematic sheet.
OwenS, if you are reading this, I haven't forgotten
your post. The idea I just mentioned came naturally to me at this point, but maybe you had planted the seed back then. Anyway, thanks for your input!
kc5tja, if you are reading this, I haven't forgotten
your post either!
Arlet wrote:
When reading from memory, the result should be provided on the DI bus 1 cycle after the RE is asserted. That's how the block RAMs do it, and that's what you should mimic if you want to have your own readable memory locations.
This is probably my problem. Right now they output data to the DI bus as soon as either of the LSB or MSB RE's are active. I will focus on correcting this.
I also found a problem with my software. The old version would have presented $01FF, instead of $0100 after incrementing from a $00FF.
This is correct:
*= $F000 ;4Kx8 ROM
begin LDY #$07
LDX #$00
STX $C004
a STX $C002
INX
BNE a
STX $C002
INC $C004
DEY
BNE a
b JMP b
Edit: Credited Owens
Edit#2: Credited kc5tja
Edit#3: Fixed spelling, added detail
