To give you an idea of the syntax and possibilities of TCB02, here is the source code for the Hangman game.
By specifying the apropriate Import and Include Files, this source code can be compiled for multiple target machines. I have so far compiled versions the 6502 Simulator, and the Vic 20.
REM Hangman Game for TCB02
REM (C) 2011 Curtis F Kaylor
IMPORT "LIB"
INCLUDE "MACROS"
DIM C, I, J, Found
DIM Word[8]
DIM Right, Wrong, Pick[15]
LABEL Start
LOCATE 0,10
PRINT "PRESS ANY KEY TO BEGIN"
REM Set Random Seed Value
LET I = 0
REPEAT
INCR I
GET C
UNTIL C <> 0
RANDOM I
REM Draw Screen
CLS
PUT #CDNRT
FOR I = 1 TO 5
PUT #HLINE
NEXT I
PUT #CDNLT
LOCATE 6,1
PUT ':'
FOR I = 1 TO 6
LOCATE 0, I
PUT #VLINE
NEXT I
LOCATE 0,7
PRINT " WORD ********"
PRINT " MISS"
LOCATE 0,10
PRINT "PRESS A LETTER "
REM Pick Word
LET Word = 8
LET I = RND() & $F8
FOR J = 1 TO 8
LET I = I + 1
LET Word[J] = WordList[I]
NEXT
REM Initialize Variables
LET Pick = 0
LET Right = 0
LET Wrong = 0
LABEL Main
REM Input Character and Convert to Uppercase
INP C
IF C>='a' AND C<='z' THEN LET C=C-32
REM Check For Break
IF C = 3 THEN STOP
REM Make sure it's a Letter
IF C<'A' OR C>'Z' THEN GOTO Main
REM See if Letter Was Already Picked
FOR I = 1 TO Pick
IF Pick[I] = C THEN GOTO Main
NEXT
REM See if Letter is in Word
LET Found = 0
FOR I = 1 to Word
IF Word[I] = C THEN
LET Right = Right + 1
LOCATE I+5,7
PUT C
GOSUB Repos
LET Found = 1
ENDIF
NEXT
REM Letter Was Not In Word
IF Found = 0 THEN
LET Wrong = Wrong + 1
LOCATE Wrong+5,8
PUT C
GOSUB BodyPart
GOSUB Repos
ENDIF
REM Add to List of Picked Letters
INCR Pick
LET Pick[Pick] = C
IF Right > 7 THEN
LOCATE 5,9
PRINT "YOU WIN!"
GOTO Start
ENDIF
IF Wrong > 6 THEN
LOCATE 5,9
PRINT "YOU LOSE!"
GOTO Start
ENDIF
GOTO Main
LABEL BodyPart
IF Wrong = 1 THEN
LOCATE 6,2
PUT 'O'
ENDIF
IF Wrong = 2 THEN
LOCATE 5,3
PUT #DLLUR
ENDIF
IF Wrong = 3 THEN
LOCATE 7,3
PUT #DULLR
ENDIF
IF Wrong = 4 THEN
LOCATE 6,3
PUT #VLINE
ENDIF
IF Wrong = 5 THEN
LOCATE 6,4
PUT #VLINE
ENDIF
IF Wrong = 6 THEN
LOCATE 5,5
PUT #DLLUR
ENDIF
IF Wrong = 7 THEN
LOCATE 7,5
PUT #DULLR
ENDIF
RETURN
LABEL Repos
LOCATE 15,10
RETURN
DIM WordList = "ABDICATE"
DATA "BACHELOR", "CALZONES", "DINOSAUR", "DUMPSTER"
DATA "DYSTOPIA". "EMPHATIC", "FATIGUED", "GERMANIC"
DATA "HARMONIC", "IGNORANT", "JEALOUSY", "KILOBYTE"
DATA "LAUGHTER", "MAGNETIC", "NOTARIZE", "ORDINARY"
DATA "PERILOUS", "QUACKERY", "REACTION", "SCROUNGE"
DATA "TAPESTRY", "VIRULENT", "BACTERIA", "AQUIFERS"
DATA "BIFOCALS", "ABNORMAL", "CAMISOLE", "DOLPHINS"
DATA "BRITCHES", "ARGUMENT", "BESTIARY"
