I am in the early stages of writing my 6502 operating system. So far I have achieved the following:
1. Cycle-perfect, interrupt-driven bit-banged RX/TX at 9600 baud using a WDC 65C22.
2. Debug code for RS232 timing (output to logic analyser for RX and TX timing analysis)
3. XMODEM implementation for binary file transfers.
4 Hardware Abstraction Layer: For when I am away from my 6502 SBC, I have implemented PY65MON aware get_char, put_char and check_char routines that are macro driven and compile accordingly depending on the target platform (PY65 or physical)
5 Terminal input - A non-blocking get_line routine handling backspaces, echoes, and null-termination (cooked input)
6. A cooperative multitasking loop (foreground_loop) with an indexed-indirect command/dictionary dispatcher.
My next goal is to get started on the command parser and monitor. Id like some input on what you find essential from a good monitor/disassembler.
DeanOS - Intro to my project
Re: DeanOS - Intro to my project
Sounds good!
Thanks. I've just come back to this after a long layoff. I've done a ton of 6502 coding in the past, but always wanted to write an OS to get to grips with the underlying design issues. It is early days, but I am enjoying the challenge.
- floobydust
Sounds like a fun project...
From your initial post, I'm thinking what you've done so far would be closer to creating a BIOS for the hardware. Do you have a hardware design in mind? Just trying to understand what you're creating.
As for monitors, I think you can likely find many examples out here and elsewhere. I think it really depends on what your goals are. Also, are you thinking disassembler or debugger? I wrote a disassembler as part of my monitor code years ago. The main reason was to include all of the additional opcodes and addressing modes for the W65C02 CPU. Writing a debugger can be more of a challenge, as you will likely need to integrate it into the hardware and provide some specific hardware features to make it more useful.
Lastly, have you come up with a set of functional requirements? I find having such a list useful so you can plan your project and get things moving more quickly. Keep us up to date on your progress.
The Apple had a "classic" monitor with the usual memory operations, single step, breakpoint, mini assembler/disassembler and so on...
The Beeb had ... An Operating System with none of that old fashioned "monitor" shenanigans. It was 1981, who needed that any-more? (was apparently the view of many, including me at that time!)
The Apple did help me learn 6502 assembly, but the Beeb really let me use it - a built in full featured assembler with macro capabilities disguised as a Basic interpreter...
So when I wrote my own system, I did start with a little Apple II-like monitor but very quickly threw it sway and ended up with an Acorn MOS compatible OS - which worked well enough to run a good number of Acornsoft ROMs directly including Basic, Comal, BCPL and so on.
The basics was a command-line interface with good line editing and history recall. (Most systems back then had a form of screen copy, but I was at the end of the serial line, so it seemed storing history was a good thing) Many built in commands (including memory fill and dump but not 'monitor' commands) with a good and well-defined interface (vectors at the top of page $FFxx) to handle character IO, filing system interface and so on.
What would I do if doing it again? I really don't know. I've racked my brains to see if I could come up with something different but I feel it's tricky to get away from what I grew up with. Apple/Beeb or a CP/M like environment. Unix for me, VMS for others... Who knows.
I am a believer in keeping things as high level as possible - to the point that if I can blink an LED, I can print a character, and if I can do that, I can print a string, then numbers, etc. "Debugging by printf" is a thing but as frown upon by as many as like it... However it works for me and has enabled me to develop a large run-time environment for my systems including a bytecode interpreter in 65816 code which enabled me to bootstrap a BCPL run-time environment and eventually get a BCPL compiler running on my 65816 hardware.
So essential for a good monitor, etc.? A very well defined IO system and interface to a filing system. Friendly keyboard input with a plethora of editing commands. My system implements
; (Simple) Editing:
; Ctrl-A - Start of Line
; Ctrl-E - End of Line
; Ctrl-D - Delete char under cursor
; Del/Bs - Delete char to left of cursor
; Ctrl-U - Delete whole line (also Ctrl-K)
; Ctrl-S - Swap this + next
; Ctrl-F - Find next char
; Esc - Abandon line
; Left/Right arrow keys move the curor.
; Characters are inserted under the cursor.
; Up/Down arrow keys wind back and forwards through history-Gordon
