After some month of tinkering with the 6502 I decided to buy a WDC W65C02SXB board. However, I am very confused regarding the TIDE IDE. So here are some questions I have:
1)
I used the youtube tutorial from WDC to do a first approach, copied a file and deleted the additional settings file as described. The following error occured:
!CreateProcess: Unable to Start Application
What application? The assembler? I let all directory settings as default.
2)
After deciding to sleep on it the next day the code assembled. However, I get a shipload of errors for code like:
File_108= VIA_ORB: equ VIA_BASE.c
File_109= VIA_IRB: equ VIA_BASE.c
What is the idea of having all lines of code ending with ".c" in an .asm file? Do I need to write code in the same syntax style?
3)
How to deal with the debugger? The built-in help in the debugger leads me to an Microsoft end-of-support website. What?!?
4)
All that weird behaviour and frustration brings me to the idea to simply use the debugger as a command-line to to upload code to the board. But as I said: No chance to RTFM. Do I have to buy a WinXP machine then...?
WDC TIDE rabbit hole
Re: WDC TIDE rabbit hole
Welcome! I can't help directly, but I see TIDE is mentioned in previous threads (not always in a good way)
WDC Tools gotcha's
WDC Terbium IDE (Tide) with the W65C816
OSI Basic won't parse commands - syntax error
WDC02CC Compiler
WDC Tools STARTUP.ASM and C samples files for 6502/816
W65C02SXB board
There's more but I'll stop there. Hopefully that, or someone here, can help.
WDC Tools gotcha's
WDC02CC Compiler
W65C02SXB board
Thanks, I'll test it.
The concept of that IDE is really of a peculiar one... but little by little the fog clears...
