vivat wrote:
Hello!
Who can share a list of resistance values between different pins of 6526? Has anyone thought of measuring interpin voltage drops with a tester in diode continuity mode?
I have doubts that my chip is working properly. But I would like to make sure that this is NOT the fault of the power supply.
Hi!
I don't think measuring resistance and/or voltage drops between pins is going to give you a clear diagnostic. There are 1000+ transistors inside a 6526 and these values are going to vary wildly between different production technologies and even batches.
You should probably aim for a software test that tries every possible use of the 6526. Are you using it as a component for your own build? Or is it inside a Commodore computer?
