Efficient memmove()
barnacle
Efficient memmove()
Post by barnacle »
I haven't started coding 6502 for my tiny basic, but one thing it's going to need is a memmove() that is capable of operating in both directions so it can move to an area its already occupying (i.e. C memmove() rather than memcpy()). It'll need to be able to move at least 32k...
It shouldn't be too complex to implement, but I'm feeling lazy and wondered if anyone had such a thing in their toolkit?
My API is expected to call with parameter 1 (destination) in Y:A, with parameters 2 and 3 (source and length) pushed on the stack before calling - parameter 3 first. A single return value would be in Y:A; the calling routine is responsible for tidying the stack up.
There is at the moment shedloads of page zero memory hanging around doing nothing.
Yuri
Re: Efficient memmove()
Post by Yuri »
teamtempest
Post by teamtempest »
Dunno how you've arranged things, but I chose the easiest possible mechanism when I implemented such a thing a few years ago in a Tiny BASIC. As I recall, one of the longest routines I needed to write:
; 	ISRT opcode - insert BASIC text line (aka INSRT)
			opcode ISRT
			; txtPtr points into input buffer
			jsr chrGot
			sty data1			; offset of first non-space after line#
			beq +				; b: first non-space is end of line
			jsr skipTxtEnd		; skip to end of line
 +			tya
			sbc data1			; (carry is set)
  			sta data1+1			; # text bytes to insert
			; look for an existing BASIC line with same line#
			; - after this txtPtr points into BASIC program text
			; at the point any insertion/deletion should happen
			jsr findLine
			bcs isrt1			; b: not found
			; delete BASIC line
			; - the easy way, just by copying each following line down
			ldx #addr1			; ... is also destination start address
			jsr moveTxtPtr
			jsr skipTxtEnd		; find start of next line
			jsr setTxtNext
			ldx #addr0			; ...which is also source start address
			jsr moveTxtPtr
			lda addr1			; put this back for possible insertion later
			ldx addr1+1
			sta txtPtr
			stx txtPtr+1
			; check if we've reached end of BASIC text
			; - which we have right away if we're deleting last line
]loop		ldy #0				; copy line#
			lda (addr0),y
			sta (addr1),y
			iny
			lda (addr0),y
			sta (addr1),y
			ldx #0
			ora (addr1,x)
			beq del1			; b: end of deletion
 -			iny
			lda (addr0),y
			sta (addr1),y
			cmp #CH_CR			; copied line ?
			bne -				; b: no
			tya					; point source to start of next line
			adc addr0
			sta addr0
			bcc +
			inc addr0+1
 +			sec					; update destination by the same amount
			tya
			adc addr1
			sta addr1
			bcc ]loop
			inc addr1+1
			bcs ]loop
del1		lda addr1
			ldx addr1+1
			jsr setTxtEnd		; update end of text pointer
			; make room for any new BASIC line
 isrt1		lda data1+1			; how much space do we need ?
			beq	isrt2			; none, so done
			; make space for new BASIC line
			clc
			lda txtEnd
			sta addr0			; set source end address lo
			adc #2+1			; account for line# plus end of line bytes
			adc data1+1			; (must be < 254)
			ldx txtEnd+1
			stx addr0+1			; source end address hi
			bcc +
			inx					; BASIC lines always < 256 chars
 +			cpx memTop+1
			bcc +				; b: < memTop
			cmp memTop
			bcc +				; b: < memTop
			jmp errMem			; >= memTop
 +			sta txtEnd			; new end of BASIC
			stx txtEnd+1
			sta addr1			; ..also destination end address hi
			stx addr1+1
			sec					; how many bytes to move ?
			lda addr0
			sbc txtPtr
			tay					; partial page count
			lda addr0+1
			sbc txtPtr+1
			tax					; whole page count
			inx					; ...plus one
			tya
			beq	mksp2			; b: no partial page to move
			sta data2
			sec
			lda addr0			; adjust source end
			sbc data2
			sta addr0
			bcs +
			dec addr0+1
			sec
 +			lda addr1			; adjust destination end
			sbc data2
			sta addr1
			bcs	mksp1
			dec addr1+1
			bcc mksp1			; b: forced
]loop		lda (addr0),y		; copy up to 255 bytes
			sta (addr1),y
mksp1		dey
			bne ]loop
 			lda (addr0),y		; copy last byte
			sta (addr1),y
mksp2		dec addr0+1
			dec addr1+1
			dex
			bne mksp1
			; insert new BASIC line
 			ldy #0
			lda linNum
			sta (txtPtr),y		; (points at insertion address)
			iny
			lda linNum+1
			sta (txtPtr),y
			ldx data1			; offset into input buffer of start of BASIC text
]loop		lda inpBuf,x
			iny
			sta (txtPtr),y
			inx
			cmp #CH_CR
			bne ]loop
isrt2		rts
barnacle
Post by barnacle »
Thanks guys; I need to study those in some detail.
At the moment, the C version makes use (obviously) of memmove:
  • First, squishbuffer() moves things around in the input text buffer to replace the line number with a 16 bit integer, converts all the tokens to single bytes, gets rid of leading space, and sticks a length byte in as the third byte in the string.
  • findline() searches the whole of the memory space to find a line either matching or above the requested line, or a zero if it gets past the last line; it returns the line number and also sets a global pointer to the memory (naughty naughty).
  • storeline() matches the line number in the buffer with the program store (findline()) and then either adds the line to the end of the store, deletes the line (if the buffer is just a number), makes a space for a new line in the store, or shuffles the store to allow a new line to replace an existing one.
It all seems to work. But I'll have to see how it looks as 65c02 code.
p.s. the code which handles print and let works identically with either the input buffer or a pointer to a specified line in memory.
