It is currently Sat Nov 23, 2024 12:22 pm
 Post subject: -TRAILING
PostPosted: Tue Sep 24, 2024 6:27 pm
-TRAILING is a Forth word which takes an address and character count of a string. It adjusts the character count to exclude trailing spaces.
I used to think -TRAILING should be implemented as a DO LOOP
: -TRAILING  ( ADR CNT1 -- ADR CNT2 )
   DUP 0
   ?DO
      2DUP + 1- C@ BL <> ?LEAVE
      1-
   LOOP ;
However, -TRAILING can be made smaller by implementing it as a BEGIN loop.
: -TRAILING
   BEGIN
      DUP
   WHILE
      1-  2DUP +  C@ BL <>
   UNTIL
      1+
   THEN ;
I did not originally set out to write this high level version of -TRAILING . I wanted a faster version of -TRAILING and wrote it as a primitive.
CODE -TRAILING
   BEGIN
      0 ,X LDA  1 ,X ORA
      NEXT.JMP 0= BRAN
      0 ,X LDA
      0= IF  1 ,X DEC  THEN
      0 ,X DEC
      CLC
      0 ,X LDA  2 ,X ADC  N STA
      1 ,X LDA  3 ,X ADC  N 1+ STA
      N )Y LDA  BL # CMP
   0= NOT UNTIL
   ' 1+ @ JMP
   END-CODE
This is from the source for my Forth's kernel. It is for a metacompiler and NEXT.JMP is a LABEL in the source for the previously defined word.
   LABEL NEXT.JMP
   NEXT JMP  END-CODE
Although I tested this new version of -TRAILING , it would have been nice to single step through it from within Forth (to see what happens to the values on the data stack).
My Forth has the word TRACE to trace the execution of high level Forth words. TRACE can not trace the execution of a primitive so I wrote a high level version of -TRAILING which works similarly to the primitive version. This version I was able to trace and it is the version I presented as the smaller version of -TRAILING . I will not be using this smaller high level version of -TRAILING . The primitive version is larger but much faster; however, I think the smaller high level version is a good reference implementation for -TRAILING .
 Post subject: Re: -TRAILING
PostPosted: Tue Sep 24, 2024 7:26 pm
Do you need strings more than 254 bytes long?  If not, you can shorten it further.
PostPosted: Tue Sep 24, 2024 7:38 pm
The Forth-83 Standard as well as the ANSI Forth standard seem to indicate that -TRAILING can handle strings much longer than 254 bytes. Removing the ability to handle long strings is not, in my opinion, worth saving a few bytes.
PostPosted: Tue Sep 24, 2024 8:47 pm
I've gone for the shorter strings for my applications, as it shortens several other words too.
PostPosted: Sat Sep 28, 2024 10:23 pm
Before I started this thread I added -TRAILING to WHERE , part of my Forth's error handling.
Before I added -TRAILING to WHERE , loading the following block
1: CREATE
2:
3:
4:
5:
6:
7:
8:
9:
A:
B:
C:
D:
E:
F:
produced this error message.
SCR# 16385 LINE# 16
@@@@@@@@@@@@@@@@@[L.@@.@U..@@@@@................................
NAME?
Adding -TRAILING to WHERE changes the error message to this.
SCR# 16385 LINE# 1
CREATE
NAME?
For this to work -TRAILING must work with strings that could be 1024 bytes in size.
PostPosted: Sun Sep 29, 2024 3:12 am
Ah-ha!  So you need a 1K block to be able to be a string.  I think Julian Noble said his book "Scientific Forth" was typeset in Forth too, and he needed a whole page to be handled as a single string.
PostPosted: Sun Sep 29, 2024 8:48 pm
When loading a block, yes. When loading a block the text interpreter treats the contents of that block as a 1K string. When not loading a block the text interpreter treats the contents of the Text Input Buffer as a string with the length of #TIB . INTERPRET uses WORD to parse text and WORD uses 'STREAM to obtain the address and length of the remainder of the text stream for the TIB or a BLOCK
: 'STREAM  ( -- ADR N )
   BLK @ ?DUP
   IF
      BLOCK B/BUF
   ELSE
      TIB #TIB @
   THEN
   >IN @
   OVER UMIN /STRING ;
It is easier to let the interpreter treat the entire block as a single string than parse it sixty-four characters at a time. It's also faster as the extra code would make 'STREAM and therefore WORD slower.
Treating a screen in a block as sixteen lines of sixty-four characters is an editing convenience. This is also why the word to comment to the end of a line in my Forth ( backslash in most Forths, but a double forward slash in my C64 Forth) increments the value of >IN to the next multiple of sixty-four when loading a block or increments it to past the text stream when not loading a block.
   'STREAM  BLK @
   IF  C/L MOD  THEN
   NIP >IN +! ; IMMEDIATE
A block does not always have to be a screen of source code. I use blocks with numbers so high they are in the Ram Expander as virtual memory in my metacompiler.
cron
