It is currently Sat Nov 23, 2024 8:11 am
 Post subject: 2/
PostPosted: Sun Sep 22, 2024 1:10 pm
Hello, I need a low level word to rshift one place in my figforth (6502) . This for a double
Thanks for any help.
 Post subject: Re: 2/
PostPosted: Sun Sep 22, 2024 1:16 pm
Sorry I mean d2/ as word for my figforth
PostPosted: Sun Sep 22, 2024 4:02 pm
How about:
   LDA  1,X   ; Get highest byte and
   ASL  A     ; put high bit in C, to
   ROR  1,X   ; preserve it while moving
   ROR  0,X   ; everything else right.
   ROR  3,X
   ROR  2,X
   JMP  NEXT
PostPosted: Mon Sep 23, 2024 9:58 am
Thanks, can you help me out with d2* ?
Thanks for any help
PostPosted: Mon Sep 23, 2024 4:57 pm
D2* is even simpler, because you don't need to preserve the sign:
   ASL  2,X
   ROL  3,X
   ROL  0,X
   ROL  1,X
   JMP  NEXT
PostPosted: Wed Sep 25, 2024 8:20 am
Thanks for the code d2* and d2/.
Is it possible to do the next two words in low level 6502?
n lshift and n rshift?
Again thanks for any help
Jan.
PostPosted: Wed Sep 25, 2024 8:21 am
I mean shifting on the standard word length.
PostPosted: Thu Sep 26, 2024 3:32 am
Is it possible to do the next two words in low-level 6502?
Sure.  A tip on "low-level" though, meaning defined in assembly language instead of defined in terms of other Forth words:  The former are called "primitives," or "code definitions," whereas the latter are called "secondaries," or "colon definitions."
        HEADER "LSHIFT", NOT_IMMEDIATE          ; ( n1 n2 -- n1' )
LSHIFT: PRIMITIVE
        LDY  0,X     ; See how many bit positions we're supposed to go.
 shLb1: BEQ  shLo1   ; If the shift distance is 0, just exit without action.
 shLlp: ASL  2,X     ; Shift the low byte of the number (putting 0 in bit 0),
        ROL  3,X     ; then the high byte, bringing bit 7 into bit 8's position.
        DEY          ; Mark off one more shift done.
        BNE  shLlp   ; If there's at least 1 more shift to do, loop again.
 shLo1: JMP  POP     ; Remove one cell from the stack, and go to NEXT.
        HEADER "RSHIFT", NOT_IMMEDIATE          ; ( n1 n2 -- n1' )
RSHIFT: PRIMITIVE
 sfRlp: LSR  3,X     ; Shift the high byte of the number (putting 0 in high bit)
        ROR  2,X     ; then low byte, bringing bit 8 in to bit 7's position.
        BNE  sfRlp   ; If there's at least one more shift to do, loop again.
I don't have these in my '02 Forth, only SHIFT which uses a negative number to mean shift right, so this is a translation from my '816 Forth where I have all three words.  I've been away from this for a while, so I hope I didn't make some dumb mistake.  Hopefully it's compatible with your figForth source and whatever assembler you're using, except that I'm not showing the macro definitions of HEADER and PRIMITIVE which do the dirty work of forming the header and (the less dirty work of) making the word a primitive.
PostPosted: Thu Sep 26, 2024 10:19 am
Thabks for the quick help.
Have implemented it in my figforth code.
But I think the RSHIFT is not working correct.
10 2 LSHIFT . 40 OK
40 2 RSHIFT . 40 OK
I include my code.
Please can youtake a look.
Jan
; LSHIFT
L8800   .BYTE   $86,"LSHIF",$D4
        .WORD   L8721
LSHIFT  .WORD   LSHIFT+2
; RHIFT
L8900   .BYTE   $86,"RSHIF",$D4
   .WORD   L8800
RRSHIFT .WORD   RRSHIFT+1
PostPosted: Thu Sep 26, 2024 10:27 am
Please discard last message, ther was an mistake in the code.
It is working fine.
Thanks
cron
