: FH \ ( offset -- offset-block ) "from here"
BLK @ ?DUP 0= IF SCR @ THEN + ;
When used in a block which is loading, FH will add the block number in BLK to the number on the data stack. This allows relative loading.
Here is an example from my system loader.
SCR# 2
// LOAD BLOCK
DECIMAL
CR .( DONE? ) 2 FH LOAD
CR .( THRU --> <-- ;S ) 3 FH LOAD
CR .( ASSEMBLER ) 4 FH 16 FH THRU
CR .( UTILITIES ) 17 FH 25 FH THRU
CR .( SF EDITOR ) 26 FH 38 FH THRU
CR .( SCREEN ED ) 39 FH LOAD
CR .( AUX STACK ) 45 FH 48 FH THRU
CR .( MORE UTILITIES AND EXTENSIONS)
CR 49 FH 80 FH THRU
CR .( VIRTUAL MEM ) 81 FH 86 FH THRU
CR .( CONDITIONAL COMP ) 91 FH LOAD
CR .( AFIND ) 92 FH 93 FH THRU
CR .( FILES (ERR) 94 FH 95 FH THRU
CR .( MULTITASKER) 96 FH 100 FH THRU
This screen of source is on block 2. When the phrase 2 FH LOAD is interpreted, the screen on block 4 is loaded.
When not loading (BLK is zero), FH adds the screen number in SCR to the number on the stack. When editing this same screen on block 2, typing 3 FH LIST will list the screen with the source for THRU , --> , <-- and ;S on block 5.
