It is currently Sat Nov 23, 2024 1:40 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Aug 28, 2024 11:59 am
prrel:
    ; show the target address of a branch instruction
    ; we've already incremented PC past the operands
    ; so it is the baseline for the branch
    ; we have the offset in A, with sign in N, C=0
        php                     ; save sign of offset
        adc pc                  ; C already clear from #args check
        tay                     ; Y is LSB
        lda pc+1
;        bcc +
;        ina
   adc #0     ; if C=0 then no change, if C=1 then it's like the INA
        plp
        bpl +
        dea
One whole byte less!...
at least you get to a round 500
PostPosted: Wed Aug 28, 2024 1:21 pm
pdragon wrote:
if you use an an 8-bit analogue of the djb2 hash where you keep a running 'sum' k and for each character circular rotate k 5 bits left and then xor with the next character, you get a single byte key which is unique over these 70 three letter mnemonics.
Are you sure about that? I tried, and get collisions for a number of them (for example, $40 for LSR, PHA, and TXS).
Collisions are OK though. I experimented with a very simple 6502-friendly hash (shift current hash left one bit, xor next character, 128 entry table). If there's a collision while building the table I bump the existing item to the next slot. Lookups are done by comparing the string in each slot until it is either found or an empty slot is found. The worst case is INX, which hash a hash of $60 but ends up in slot $67. Items that aren't in the table can take a lot longer, but they're errors so their speed is less important.
This would help an assembler, not a disassembler, and it helps speed rather than size, so would perhaps be more suited to its own thread if anyone wants to continue.
That disassembler is incredible. The operand packing is particularly genius, and the code is surprisingly readable for something so intricate.
PostPosted: Wed Aug 28, 2024 4:47 pm
yup, i think i messed up my hash test... the collision idea is nice tho. agree lets do a new thread if assembler idea gets traction
PostPosted: Wed Aug 28, 2024 5:20 pm
There is a bunch of stuff out there about creating perfect hashes.
Also, the chess community has created some very interesting techniques for dealing with things like this...
PostPosted: Thu Aug 29, 2024 1:29 am
Hi!
But we don't want a perfect hash, we need collisions for all the bytes that map to the same opcode name - this is what makes finding the hash difficult :)
Have Fun!
PostPosted: Thu Aug 29, 2024 10:43 am
Another nice contribution from dmsc gets us to 500/560
PostPosted: Thu Aug 29, 2024 2:26 pm
Maybe we can get billions of 6502 fans to do a distributed hash search on all those billions of 6502 devices WDC sold!
PostPosted: Sat Aug 31, 2024 2:13 am
Added a description of dmsc's nice indexing and data overlap strategy so I'd understand it next time I looked at it, and got dragged in to another game of data tetris myself. Ridiculous cost/benefit to save 3 bytes. But now 497/557. Here's a snippet from the comments:
The data layout is quite intricate to create some areas where
different data structures overlap to save space.  Here's a rough sketch:
|   slice masks    |
|   16-18 bytes    |
| mnemonics 0..$40 |   (other data)  | spc mnemonics $44..$4c/$50 |
|     64 bytes     |     8 bytes     |        16 - 24 bytes       |
                 |  operand template   |
                 |   8 byte string     |
|  mode tbl 0..$20  |      (other data)     |  spc modes $7f-$7f  |
|   16 bytes        |        42 bytes       |      6 bytes        |
                /    8 + 12 + 15 + 15           \
             /              - 1 - 5 - 2            \
          /                     = 42 bytes            \
        | formats |  1 byte overlap                     |
        | 8 bytes | /                                   |
                | spc mode opcs |  5 byte overlap       |
                |   12 bytes    | /                     |
                          | spc mnem opcs |  2 byte overlap
                          |   15 bytes    | /           |
                                      |  spc mnem idxs  |
                                      |     15 bytes    |
PostPosted: Sat Aug 31, 2024 7:15 am
Very nice! Thanks for sharing.
PostPosted: Sat Aug 31, 2024 9:47 am
Lovely simplification from dmsc to get rid of two more loop index checks. Reversed one and realized only parity matters in another.
Also spotted that sta adr,y is 3 bytes vs 2 for sta adr,x for zp address since it has no short mode. I had to compare assembly listings to see where that extra byte had gone!
Now 492/552.
