Hello friends. Long time (lost my password). Hope everyone is well.
I've spent the last n days setting up and debugging yosys/apycula open-source toolchain, which is not bad these days and supports Gowin chips.
Nano 9K, at $20, is pretty amazing: a reasonably-sized FPGA (a minimal system with Arlet's core is 10% utilization), 48KB of block RAMs, 64Kbit SDRAM, lots of flash, USB for power, configuration and serial, SD card, HDMI hardware and an LCD connector. And a bunch of IO pins, 6 LEDs and 2 buttons.
On the negative side, Gowin FPGAs are on par with cheaper Lattice parts, and I miss the features of even low-end Xilinx chips, such as the up-to-16-bit SRL16 shift-register directly in a single LUT...
Anyway, I think this is the best deal this century for FPGA hobbyists. There is also the $10 Nano1K, which is probably too small for anything interesting, a $15 Nano4K with a hard ARM cell on the FPGA, and the $30 Nano20K which has a faster/bigger FPGA...
As mentioned, I managed to hack up a quick-and-dirty 6502 system to flash an LED, running at stock 27MHz. The Gowin toolchain takes about 1 minute, the free toolchain around 30 seconds to build it. Almost reasonable (I was building small Xilinx systems in 10-15 seconds, but that was after a year of fiddling with the makefile, so I am still hopeful about yosys).
The board is big enough to support pretty much any 6502 system, I think. I'll see if I can make a CHOCHI work-alike and get forth and BASIC up to start with.
Link to repo with my 6502 experiments:
https://tildegit.org/stack/Tangnano9K-65c02-experiments
