It is currently Sat May 11, 2024 9:34 am
PostPosted: Mon Mar 04, 2024 9:18 am
... remembering that the data stored at the SSR must have its bits flipped, since the 6522 SR is least significant bit first rather than most significant bit first.
The 6522 SR is MSB first!
Dietrich
My system: Elektor Junior Computer, GitHub https://github.com/Dietrich-L
PostPosted: Mon Mar 04, 2024 9:38 am
Right.  It's the '51 and all UARTs that go lsb-first.
PostPosted: Mon Mar 04, 2024 2:14 pm
While there is much talk about just receiving the data with the SR (or in general). SPI is a bidirectional protocol, you need to be able to send commands as well.
So, if you use the VIA SR to receive data, I assume to get as fast as you can, you use Phi2 clock input for the SR. that means that you need to use CB1 clock output as source for the SPI clock. And then you end up in the mode 0 / mode 3 mess already again, right? I even wonder how you are going to receive mode 0: data is shifted out when /SEL activates (first valid bit), and on falling clock of SCLK. If you use the inverted SR clock as SPI clock, you shift the data in exactly when the device already shifts out a new bit. That typically works if the device goes by the "specification". I've done that as well, but it is not a good design. You would need a delay circuit for the clock anyway, as Bruce has proposed in the other thread.
But how are you going to send data? If you switch SR direction, you need to switch SR output CB2 between MISO and MOSI, which costs additional gates and a gate that switches direction.
You can bit-bang data out on MOSI - but then you need to have a way to send pulses on SPI clock also - despite it is driven by SR clock (CB1) when receiving. Again additional gates.
Ok, at a minimum hardware you could use an NAND between CB1 and a port bit used as SPI clock output when sending to drive the SPI clock, put MOSI from another port bit and MISO to the SR input. But that means that anytime you want to send data you have to bit-bang it. (Note that I'd probably use the clock delay from here download/file.php?id=20395&mode=view and connect the output clock port bit to IC2 pin 12, to have a more compliant SPI mode 0 clock).
Yet, at the cost of that single external serial-to-parallel shift in chip, I firmly believe that this download/file.php?id=20395&mode=view is a very balanced and efficient approach in terms of hardware and software used, and provides full speed in both directions.
     BIT PORTA   ; trigger /ACK for clock circuit
     ; ... per byte
     STA SR      ; trigger transfer
     LDX #$FF
L0   LDA #4
L1   BIT IFR   ; check
     BEQ L1
     LDA PORTA  ; read incoming data
     STX SR    ; trigger next transfer (by sending $ff in this case)
     ; process received data (e.g.)
     STA (ZP),Y
     INY
     BNE L0
If you count clock cycles, and your processing time is long enough, it may even be possible to remove the IFR check.
You may need to be careful with the end condition.
PostPosted: Mon Mar 04, 2024 5:46 pm
Oh my goodness, I was misreading the datasheet ... all of the timing diagrams say "1" through "8" on the serial data line, but the notes on page 21 say that bitt7 is shifted out first and bits are first shifted into bit0.
But how are you going to send data? If you switch SR direction, you need to switch SR output CB2 between MISO and MOSI, which costs additional gates and a gate that switches direction. ...
Yeah, just using the SSR as a dedicated MISO best fits a serial Flash, especially the 256 byte sector serial Flash, where you would typically be putting out a few bytes and then reading a sector. You need a single AND gate to merge the input byte serial clock from the SSR and the output byte serial clock from a GPIO, and that's it ... because serial Flash are typically Mode0/Mode3.
So that's pretty much a "minimum extra chips" circuit, thought the downside is that single logic gates tend to be in SMB packages.
But if you are even going to SPI mode SD, I reckon that the two chip circuit using the VIA SSR and a separate serial shift register is the way to go.
PostPosted: Wed Apr 03, 2024 6:20 pm
Dietrich wrote:
The fastest Code to read a SD card is, to my knowledge, this one:
SPI_BIN   LDA IFR      ;read byte from SPI
   AND #$04   ;test SR bit
   BEQ SPI_BIN
   STA IFR      ;clear SR bit
   LDA SR
   RTS
How about:
SPI_BIN: LDA  #4
 1$:     BIT  IFR
         BEQ  1$        ; (shorter loop)
         LDA  SR        ; (This clears the IFR's SR bit.)
         RTS
Perfekt. Thanks. I will use that for sure
Dietrich
cron
