It is currently Thu May 09, 2024 12:32 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Mon Mar 11, 2024 2:35 am
What are the blo and bhs mnemonics?  (apparently aliases for existing branch instructions)
And do you have the CMOS instruction set available to you?
PostPosted: Mon Mar 11, 2024 3:55 am
blo is an alias for bcc and bhs for bcs
They keep me from forever refiguring out whether the carry flag is set on borrow. The mnemonic device is that the 6502 has it backward for when I have to.
I come from the 680x world where in addition to beq and bne, there are four unsigned relative branches:
blo - branch if lower
bls - branch if lower or same
bhs - branch if higher or same
bhi - branch if higher
I do not alias bls or bhi because they are not equivalent to single instructions.
My own tools currently support only the NMOS instruction set because I consider OSI and early Apple II as significantly important platforms. And I do not use undocumented instructions.
