Hello again! And thanks for the photos.
I still have lots of questions. And BTW I hope you noticed the point that Dave (Hoglet) mentioned.
For ROM and RAM i'm using 3.3 to 5v converter (they are CMOS so i think they need higher voltage to be active)
I'm pretty sure the voltage converters are not necessary. The ROM and RAM are not the same as logic chips such as the 74HC series. Even though the ROM and RAM may be fabricated in a CMOS process, chips like that usually have inputs that accept TTL voltage levels. I believe this is true for 28C256 and 62256. I haven't checked those datasheets, but the answer will be there.
BTW, is your CPU an actual 6502 (ie, NMOS)? Or is it a 65
C02, from Rockwell perhaps, or WDC?
I also have D flip/flop for decoding R/!W signal for tms9918
Sorry, I don't understand. A SCHEMATIC would be really helpful!
I know you said the project was working fine when you had 74 series chips for the glue logic... and the trouble started after you replaced the 74 series glue with the 7032 PLD. But we cannot be certain the trouble came from the 7032.
There are several other possibilities. For example there may be a problem with bad connections... connections which were OK for a while but then got disturbed when you made the wiring change. (Solderless breadboards are notorious for unreliable connections.
That is why we will have questions about many subjects... not just the 7032.
