It is currently Sun May 12, 2024 5:42 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: 8521 dissection
PostPosted: Fri Jan 06, 2023 10:15 pm
Now we can compare with https://ist.uwaterloo.ca/~schepers/MJK/cia6526.html and see of the theories were correct :-)
PostPosted: Sun Jan 08, 2023 9:34 pm
From what I've learnt with the 74HCT6526 project, and now that I've managed to make a cycle exact replica of them, Wolfgang model is spot on, at least, regarding the timers.
PostPosted: Thu Feb 15, 2024 6:48 pm
ttlworks wrote:
When the hour counter reaches 12, PM toggles.
Note, that the ML output carry doesn't go into the equation,
so writing decimal 12 into the hours if the hours already were not 12 this will toggle PM.
PM flag:
We have sort of a comparator which checks if HH=1 and if HL=$2.
The rising edge of the comparator output toggles the PM flag.
Again, note that the MH output carry doesn't go into this.
The PM flag toggles when TOD reaches 12:00:00, that yes.
But a side effect is that when writing "HH=1 and HL=$2" to the TOD_HR register,
and the TOD_HR register previously was not "HH=1 and HL=$2", this toggles the PM flag.
In this case, you would have to write with the PM Bit _inverted_ into the TOD_HR register
to compensate for this.
This strongly implies (but reading carefully, it doesn't literally say it) that writing $12 to the Hours register when it already contains that value will *not* toggle PM.
But it seems that that is not the case. Even writing $12 when it was $12 already toggles PM, according to tests that have been reported to the VICE team: https://sourceforge.net/p/vice-emu/bugs/1988/
Was this how the above explanation was meant, or is this unexpected? If the latter, could this work out differently on different CIA models perhaps?
PostPosted: Fri Feb 16, 2024 12:03 pm
rhialto, sorry to say this:
It's been more than a year, meanwhile we dissected some other chips,
and since December 2023 the chip dissections are put on hold.
Me and Frank usually only had the capacity for dissecting the latest revision of a chip,
we simply can't cover all revision of a chip.
Also, 8521 "is supposed to be" "sort of a drop in replacement" for the 6526,
but we never found the time to take a closer look at the 6526.
PM flag is quite difficult stuff, and digging into it again would take me some time.
PostPosted: Fri Feb 16, 2024 1:18 pm
Maybe we will take a look at that as soon as the 6526 has been vectorized and dissected. But this may take some time... if not years until this happens. (If it will ever happen at all!) :)
