It is currently Fri Nov 01, 2024 2:33 am
PostPosted: Mon Nov 03, 2003 3:37 pm
I'm trying to write a 6502 emulator in MIPS assembly code and then hopefully in the future, I can implement it with some games. I have the core working, but I'm having trouble with my branch instructions. Is there anyone familiar with MIPS?
PostPosted: Mon Nov 03, 2003 3:40 pm
I can provide the source code if anyone wants to check it out.
PostPosted: Tue Nov 04, 2003 12:52 pm
I do more MIPS than is good for me. What problem are you having with the branches? Don't forget that most of them (the ones without the l "likely" suffix) will always execute the following instruction.
 Post subject: From Jerod
PostPosted: Tue Nov 04, 2003 2:08 pm
Would you like to see the source code? I've found people have a better time understanding my problems with source code if they see it. It's also because I'm terrible at explaining my problems. In any case, I'm having a hard time conceptualizing how the branch instructions are to be implemented. I thought that it might be a simple matter of just using a move pseudoinstruction but that doesn't seem to work. I think it's little more involved than that(of course!). Maybe I have to have a couple subroutines or whatever you call them in MIPS.
 Post subject: Re: From Jerod
PostPosted: Tue Nov 04, 2003 10:04 pm
It helps if you actually tell us, or even give us a hint of, what your problem actually is. :) You're proposing possible solutions above, but without any detail about where your confusion is coming from.
I'm assuming you're refering to how the 6502's branch instructions work. Basically, the operand to a branch instruction is an 8-bit, 2's-compliment signed offset from the address following the branch instruction.
What this means is, if the condition tested by that branch instruction is true, it will add the sign-extended offset operand to the current value of the program counter (remember: after fetching the offset byte, it points immediately after the branch instruction; therefore, if the branch instruction sits at $C000, the PC will point to $C002). Program execution will then resume at the new location. Otherwise, if the tested condition is false, it will continue execution immediately following the instruction ($C002 in my makeshift example above).
Does this help any?
