6502.org Forum  Projects  Code  Resources  Tools  Forum
It is currently Tue Jun 18, 2013 11:38 pm
 Post subject: V2.20
PostPosted: Tue Apr 27, 2010 1:35 am
V2.20 Fixes an undocumented feature of IF as well as adding an optional ELSE clause and can be found here ..
http://www.themotionstore.com/leeedavison/6502/ehbasic/index.html
Lee.
PostPosted: Tue Apr 27, 2010 6:51 pm
Lee,
Would it be easy to port your Basic to a WDC 65C816?
Chuck
PostPosted: Tue Apr 27, 2010 11:23 pm
Chuck,
I am running EHBasic in native mode on my SBC-3 so I know it can be done.
I have notes on my website on the changes I made.
http://sbc.rictor.org/download/EhBASIC.zip
EDIT: I have made most of the changes to the new version of EHBasic and was able to run a simple program on WDC65816 in native mode. I did have some trouble with the load and save functions, that's most likely my support code, not EHBasic.
Once I have it all complete, I'll update my website and post it here.
PostPosted: Wed Apr 28, 2010 1:31 pm
Great job Lee!!!
Thanks for continuing to develop this program!
I discovered one thing to look out for when upgrading to version 2.20.
My method of saving EHBasic programs is to scan RAM from smeml, smemh until I find the end of the program. I then do a binary save of that range to disk.
When loading a program written in v2.10 into v2.20, some of the tokenized commands are changed, due to the insertion of new tokens in the table.
what was
20 FOR x = 1 to 10
30 PRINT X , X^2
becomes
20 FOR x > 1 ELSE 10
30 PRINT X, X/2
The good side is that a conversion tool could easily be written to update the program files.
PostPosted: Wed Apr 28, 2010 5:58 pm
Yes, sorry about that but it is pretty much unavoidable. I've given up on bianry LOADs and SAVEs on my systems for this very reason.
As there is only one new token, TK_ELSE - which is $AC, it should just be a case of scanning the program from start to end and incrementing every token byte of $AC or more.
Lee.
PostPosted: Wed Apr 28, 2010 7:48 pm
The DEEK in line 63010 needs to be to Smeml which is $79 in my case.
62999 END
63000 el=62999
63010 nl=DEEK($79)
63020 DO
63030   ln=DEEK(nl+2) : IF ln<0 THEN ln=ln+$10000
63040   ? "Line"; ln
63050   ad=nl+3
63060   nl=DEEK(nl)
63070   DO
63080     INC ad
63090     b=PEEK(ad)
63100     IF b>$AB THEN INC b : POKE ad,b
63110   LOOP WHILE b
63120 LOOP WHILE ln<el
63130 ? "All done!"
This can be appended to the end of any program and executed with RUN 63000
Lee.
PostPosted: Wed Apr 28, 2010 9:50 pm
Lee,
I understand the need for the change and it no real problem. You've already created the tool to adjust it which is great too.
I have completed the changes for V2.20 to run on SBC-3 (my earlier problem was in my supporting routines). I'll get the updated version loaded on my site soon.
thanks again Lee!
PostPosted: Thu Apr 29, 2010 1:19 am
Tokenization is a good thing to do for several reasons, but for the purposes of data import and export, its primary value is in the compression it offers. After studying LZ78 compression, you start to realize that a tokenized source file is completely equivalent to an LZ78-compressed text file with a statically predetermined dictionary.
In other words, you can get all the same benefits of tokenized source code if you just compress your raw text source (e.g., using PKZIP, for example). Perhaps, then, a binary load/save command can be added which is nothing more than a raw text load/save command piped through a post-compression or pre-decompression stage first.
PostPosted: Fri May 07, 2010 2:55 pm
I've taken a couple cracks at adding the 2.20 changes to my port of 2.10. Since my 2.10 is so heavily hacked this is a bit trickier. Probably "third time's the charm" though.
In my case, a redundant token (CATALOG, which was intended to produce an 80-column-wide directory listing while CAT produced a 40-column listing - like BASIC.SYSTEM) could be recycled. I have no room for new tokens.
PostPosted: Fri May 07, 2010 10:43 pm
I've put the details of the changes made here
Lee.
