64Forth, a FIG Forth written by Tom Zimmer for the Commodore 64, was the first Forth I used. It is the only FIG Forth I've used. From time to time I may post more insights into the working of 64Forth as it may be of use to those using FIG Forth. If anyone else has useful insights into this implementation of FIG Forth, please share your thoughts.
This is what I've been able to uncover about 64Forth's handling of the text stream.
64Forth has sixteen buffers, twelve in the RAM underneath the kernel ROM at $E000 - $FFFF and the I/O section at $D000 - $DFFF and four in the ram at $C000 - $CFFF.
64Forth uses a single communications buffer to act as an interface to these buffers. All access is with the communications buffer. There is a zero stored in the two bytes just past the communications buffer.
64Forth has a version of SEE named SOURCE which was used to decompile EXPECT .
: EXPECT OVER + OVER (DO) EFLAG @ 0BRANCH 8 KEY
BRANCH 4 CHRIN DUP CLIT 14 = 0BRANCH 2A DROP CLIT 9D
DUP EMIT SPACE OVER I = DUP R> 2 - + >R CLIT 93
* - BRANCH 2C DUP CLIT D = 0BRANCH E LEAVE DROP
BL 0 BRANCH 9 DUP CLIT 7F AND I C! 0 I 1+
! EFLAG @ 0BRANCH 8 EMIT BRANCH 4 DROP (LOOP) -7F
DROP ;S
and here is the probable source.
: EXPECT
OVER + OVER
DO
EFLAG @
IF KEY ELSE CHRIN ENDIF
DUP #20 =
IF
DROP #157 DUP EMIT SPACE
OVER I = DUP R> 2 - + >R #147 * -
ELSE
DUP #13 =
IF
LEAVE DROP BL 0
ELSE
DUP #127 AND
ENDIF
I C! 0 I 1+ !
ENDIF
EFLAG @
IF EMIT ELSE DROP ENDIF
LOOP
DROP ;
Notice this section of the source.
I C! 0 I 1+ !
As 64Forth's EXPECT is storing text in memory, it is following that text by two zeros.
64Forth's ENCLOSE takes the address of the remaining text to process and a delimiter. It returns that same address and an offset to the start of the next word, the offset to the delimiter after that word and the offset to add to IN , 64Forth's word for >IN . When ENCLOSE encounters a zero after skipping any leading delimiters, it returns, along with the address passed to it, the offset to the location with zero, the offset to the location after zero and the offset for IN .
The decompilation of 64Forth's WORD
: WORD BLK @ 0BRANCH 12 BLK @ BLOCK BRANCH 6 TIB
@ IN @ + SWAP ENCLOSE HERE CLIT 34 BLANKS IN
+! OVER - >R R HERE C! + HERE 1+ R> CMOVE
;S
and the probable source.
: WORD ( DELIMITER -- )
BLK @
IF
BLK @ BLOCK
ELSE
TIB @
ENDIF
IN @ + SWAP ENCLOSE
HERE 34 BLANKS IN +!
OVER - >R R HERE C!
+ HERE 1+ R> CMOVE ;
Notice 64Forth's WORD does not leave an address on the data stack.
64Forth's WORD uses the data from ENCLOSE to update IN and store a counted string at HERE . When the zero byte is the only text left in the buffer, the string at HERE has a count of 1 and zero for the text. There is a word with this name in 64Forth. This word is immediate. In 64Forth the count byte and the byte with the last character of a name have their high bit set. The name field of this mystery word is the following: $C1 $80. This is an immediate word with a length of one and a single null character for the name.
: BLK @ 0BRANCH 4 ?EXEC R> DROP ;S IMMEDIATE
64Forth's INTERPRET is an infinite loop. This word, when found, is used to break out of INTERPRET .
In summary, 64Forth's EXPECT does store a zero after the text and the communications buffer has a zero in the two memory locations following the buffer.
When this zero is encountered, a word is executed which exits INTERPRET .
