IamRob wrote:
BruceRMcF wrote:
IamRob wrote:
... Back to the zero at the end of words, after EXPECT has input a word definition, then when following INTERPRET, it isn't clear how INTERPRET ends.
";" finishes up the definition, compiling EXIT and clearing the smudge bit, and setting state to interpret, but then INTERPRET would continue with the next token encountered.
This is what doesn't make sense though. Variables and constants don't end with a ";", so when interpreting TIB, there needs to be something to indicate end of input.
But the end of a definition has nothing to do with the end of a line.
: this. 1 . ; : that. 2 . ; : theother. 3 . ;
... is perfectly well formed forth. Not including anything after the ";" on a line is just a convention, it is not syntax.
";" ends the definition and changes the state back to interpret mode. Variables, constants, ":" and other defining words need more input because they take the name they are defining from the input stream, but regular compiling words like ";" or "IF" don't care if anything is following them or not.
IamRob wrote:
... UniForth, which is based on '83 Forth, is the first Forth that I have come across that has a Forth editor and has both SPAN and #TIB, but I am not seeing where INTERPRET comes across them to end interpreting in the TIB, nor is there a zero to end interpreting. I was hoping to understand how INTERPRET uses either of these words, so I can then hopefully eliminate the zero in my Fig Forths.
I'm more familiar with CamelForth than UniForth, so I'll say how it does it. I was wrong when I called INTERPRET an endless loop, it is QUIT that is an endless loop, and INTERPRET is the common factor for interpreting a single chunk of text, whether an input line in TIB, a Forth expression in a string to be evaluated with EVALUATE or in a BLOCK.
CamelForth INTERPRET works with a BEGIN / WHILE / REPEAT loop, where the loop control is:
... BEGIN BL WORD DUP C@ WHILE ... REPEAT ...
... which uses a Forth79/Forth83/ANSForth lineage "WORD" that returns the address of the transient buffer being used by WORD. It is WORD that detects that the TIB is exhausted when it returns a zero-length string.
Now, fig-Forth WORD does not return the address of the transient WORD buffer, but it does work by copying the parsed text into a transient buffer, so if you rewrite WORD so that it first checks whether there is nothing left to parse in the buffer, and in that case rather than parsing, you store a 16-bit zero into the WORD buffer -- one zero byte for the zero count, and one zero byte for the trailing NUL -- that might be enough for the fig-Forth INTERPRET, so that there doesn't have to be a NUL in the TIB itself.
