It is currently Fri May 17, 2024 9:46 pm
 Post subject: ANN: HXA 1.000
PostPosted: Fri Jan 05, 2024 5:54 pm
https://github.com/AntonTreuenfels/HXA-Cross-Assembler-1.000
Only ten years after the last version, a new release.
Notable differences:
- source language is Python 3.11.4 (updated from Thompson AWK 5.0)
- support for Unicode (several forms) and Latin-1 text output (in addition to ASCII)
- an explicit string concatenation operator (instead of an implied one)
- a new "raw" output text file of just hexadecimal character data (in addition to the more decorated Motorola SRecord and Intel Hex forms)
- a single "cpu-aware" module is dynamically loaded at run time (add native support for any cpu just by writing a new module)
There are a few bug fixes, like incorrect extensions on 16- and 32-bit cpu SRecords (now always T- and U- records, as was discussed years ago).
It currently passes all existing regression and demonstration tests.
Any re-writing of existing code is mostly going to be limited to adding the string concatenation operator and doubling any single escapes in regular expression literals.
 Post subject: Re: ANN: HXA 1.000
PostPosted: Fri Jan 05, 2024 6:05 pm
Wow - I do believe I remember coming across that, the combination of 6502 and awk being just my kind of thing! But surely the change is a good idea. (In fact checking my mails, looks like I was briefly in conversation with Anton.)
PostPosted: Fri Jan 05, 2024 7:23 pm
The link I had for it on my links page went dead, so I replaced it with the archive.org link, https://web.archive.org/web/20190208204 ... .net/~hxa/ .  It's nice to see it's back now, with improvements.
