Hi,
I'm wondering how the address is computed on the IIgs Ram Expansion Slot....
I see FRA0..9...
The 65C816 has a 24-bit address bus.
The 16-bit low part is like the 6502. And there are the 8-bit Program/Data Bank Register.
So why 10 bits on this slot (FRA0--9) ?
And what is the use of the A10..15 on the slot ?
IIgs Ram Expansion slot Pinout explanation
Re: IIgs Ram Expansion slot Pinout explanation
The "Apple iiGS Hardware Reference" will probably answer your questions. Do you have access to that PDF? (Perhaps you do, but find it hard to interpret.)
And it might be helpful if you tell us why you're asking. For example, is it mere curiosity? Are you thinking of building a card that would plug into the Ram Expansion Slot?
- BigDumbDinosaur
Not exactly. The 816 generates a 24-bit address (even in emulation mode), but multiplexes bits 16-23 on the data bus during Ø2 low. Typically, a transparent latch is used to capture those bits when the clock is low and then maintain them when Ø2 goes high.
Correct. That feature is necessary to support 65C02 emulation capability.
From a hardware decoding standpoint, the contents of DB and PB are not relevant unless the glue logic monitors the state of VDA and VPA. If that is the case, then the glue logic will “know” when a cycle is an opcode fetch (VDA && VPA is true), operand fetch (!VDA && VPA is true) or data fetch/store (VDA && !VPA is true). From that, it can be inferred if PB is influencing the effective address, since it is PB that determines bits 16-23 during opcode and operand fetches. However, while VDA && !VPA tells you that a data fetch/store is occurring, it doesn’t tell you if bits 16-23 reflect what is in DB. This is because an effective address generated by the absolute-long or indirect-long addressing modes does not get bits 16-23 from DB.
The answer to that is likely in the manual mentioned by Jeff.
Thanx a lot guys.
Oh yeah, the hardware ref.... damned.. I used to have this book....
Get rid of almost everything some 23 years ago....
yep, stupid.
just downloaded it
Perfect.
Right now, yes, it is.
still grooming
I'm a software engineer, hence the inacurate HW description.
But yop, you're definitively right. And that's part of the difficulties to deal with the 65C816.
Timing is the essence.
yep, stupid.
still grooming
BigDumbDinosaur: Not exactly.
