Well, in between painting this, and laying a floor that, and carrying boxes the other... I managed to knock together a little bit of test hardware. And, woohoo, the SVGA line timing works and is spot on... though the circuit looks like it was put together by an inebriated spider...
Line sync is 3.2us:
Line blanking is a touch longer than spec; I'm using only 384 of my 400 horizontal pixels:
And the line timing is exactly 26.4us:
All this in just six and a bit chips (there's a seventh chip in there to generate the load pulse for the parallel to serial chip, but I didn't count that
) and it's perhaps interesting in that it uses - after the initial 20MHz tp 2.5MHz divider - ripple counters and decoders. The count always increments in such a way that there aren't any glitches that affect the outputs.
The field generator works in a similar, but not identical, way, so that's next to check if it fits on the board.
