I took the code from here
http://www.6502.org/source/interpreters/sweet16.htm
The original article is here
https://archive.org/details/byte-magazi ... ew=theater
code from this site
SW16D LDA >SET ;COMMON HIGH BYTE FOR ALL ROUTINES
PHA ;PUSH ON STACK FOR RTS
LDY $0
LDA (R15L),Y ;FETCH INSTR
AND $F ;MASK REG SPECIFICATION
LDY #$0
AND #$F ;MASK REG SPECIFICATION
I would change change the .ORG and zero page usage
;* APPLE-II PSEUDO MACHINE *
;* INTERPRETER *
;* COPYRIGHT (C) 1977 *
;* APPLE COMPUTER, INC *
;* ALL RIGHTS RESERVED *
;* S. WOZNIAK *
;* TITLE: SWEET 16 INTERPRETER *
R0L .EQU $0
R0H .EQU $1
R14H .EQU $1D
R15L .EQU $1E
R15H .EQU $1F
.ORG $F689
;AST 32
JSR SAVE ;PRESERVE 6502 REG CONTENTS
PLA
STA R15L ;INIT SWEET16 PC
PLA ;FROM RETURN
STA R15H ;ADDRESS
SW16B JSR SW16C ;INTERPRET AND EXECUTE
JMP SW16B ;ONE SWEET16 INSTR.
SW16C INC R15L
BNE SW16D ;INCR SWEET16 PC FOR FETCH
INC R15H
LDY #$0
ASL ;DOUBLE FOR TWO BYTE REGISTERS
TAX ;TO X REG FOR INDEXING
LSR
EOR (R15L),Y ;NOW HAVE OPCODE
BEQ TOBR ;IF ZERO THEN NON-REG OP
STX R14H ;INDICATE "PRIOR RESULT REG"
LSR
LSR ;OPCODE*2 TO LSB'S
LSR
TAY ;TO Y REG FOR INDEXING
LDA OPTBL-2,Y ;LOW ORDER ADR BYTE
PHA ;ONTO STACK
RTS ;GOTO REG-OP ROUTINE
TOBR INC R15L
BNE TOBR2 ;INCR PC
INC R15H
TOBR2 LDA BRTBL,X ;LOW ORDER ADR BYTE
PHA ;ONTO STACK FOR NON-REG OP
LDA R14H ;"PRIOR RESULT REG" INDEX
LSR ;PREPARE CARRY FOR BC, BNC.
RTS ;GOTO NON-REG OP ROUTINE
RTNZ PLA ;POP RETURN ADDRESS
PLA
JSR RESTORE ;RESTORE 6502 REG CONTENTS
JMP (R15L) ;RETURN TO 6502 CODE VIA PC
SETZ LDA (R15L),Y ;HIGH ORDER BYTE OF CONSTANT
STA R0H,X
DEY
LDA (R15L),Y ;LOW ORDER BYTE OF CONSTANT
STA R0L,X
TYA ;Y REG CONTAINS 1
SEC
ADC R15L ;ADD 2 TO PC
STA R15L
BCC SET2
INC R15H
SET2 RTS
OPTBL .BYTE SET-1 ;1X
BRTBL .BYTE RTN-1 ;0
.BYTE LD-1 ;2X
.BYTE BR-1 ;1
.BYTE ST-1 ;3X
.BYTE BNC-1 ;2
.BYTE LDAT-1 ;4X
.BYTE BC-1 ;3
.BYTE STAT-1 ;5X
.BYTE BP-1 ;4
.BYTE LDDAT-1 ;6X
.BYTE BM-1 ;5
.BYTE STDAT-1 ;7X
.BYTE BZ-1 ;6
.BYTE POP-1 ;8X
.BYTE BNZ-1 ;7
.BYTE STPAT-1 ;9X
.BYTE BM1-1 ;8
.BYTE ADD-1 ;AX
.BYTE BNM1-1 ;9
.BYTE SUB-1 ;BX
.BYTE BK-1 ;A
.BYTE POPD-1 ;CX
.BYTE RS-1 ;B
.BYTE CPR-1 ;DX
.BYTE BS-1 ;C
.BYTE INR-1 ;EX
.BYTE NUL-1 ;D
.BYTE DCR-1 ;FX
.BYTE NUL-1 ;E
.BYTE NUL-1 ;UNUSED
.BYTE NUL-1 ;F
;* FOLLOWING CODE MUST BE
;* CONTAINED ON A SINGLE PAGE!
SET BPL SETZ ;ALWAYS TAKEN
LD LDA R0L,X
BK .EQU *-1
STA R0L
LDA R0H,X ;MOVE RX TO R0
STA R0H
RTS
ST LDA R0L
STA R0L,X ;MOVE R0 TO RX
LDA R0H
STA R0H,X
RTS
STAT LDA R0L
STAT2 STA (R0L,X) ;STORE BYTE INDIRECT
LDY $0
STAT3 STY R14H ;INDICATE R0 IS RESULT NEG
INR INC R0L,X
BNE INR2 ;INCR RX
INC R0H,X
INR2 RTS
LDAT LDA (R0L,X) ;LOAD INDIRECT (RX)
STA R0L ;TO R0
LDY $0
STY R0H ;ZERO HIGH ORDER R0 BYTE
BEQ STAT3 ;ALWAYS TAKEN
POP LDY $0 ;HIGH ORDER BYTE = 0
BEQ POP2 ;ALWAYS TAKEN
POPD JSR DCR ;DECR RX
LDA (R0L,X) ;POP HIGH ORDER BYTE @RX
TAY ;SAVE IN Y REG
POP2 JSR DCR ;DECR RX
LDA (R0L,X) ;LOW ORDER BYTE
STA R0L ;TO R0
STY R0H
POP3 LDY $0 ;INDICATE R0 AS LAST RESULT REG
STY R14H
RTS
LDDAT JSR LDAT ;LOW ORDER BYTE TO R0, INCR RX
LDA (R0L,X) ;HIGH ORDER BYTE TO R0
STA R0H
JMP INR ;INCR RX
STDAT JSR STAT ;STORE INDIRECT LOW ORDER
LDA R0H ;BYTE AND INCR RX. THEN
STA (R0L,X) ;STORE HIGH ORDER BYTE.
JMP INR ;INCR RX AND RETURN
STPAT JSR DCR ;DECR RX
LDA R0L
STA (R0L,X) ;STORE R0 LOW BYTE @RX
JMP POP3 ;INDICATE R0 AS LAST RESULT REG
DCR LDA R0L,X
BNE DCR2 ;DECR RX
DEC R0H,X
DCR2 DEC R0L,X
RTS
SUB LDY $0 ;RESULT TO R0
CPR SEC ;NOTE Y REG = 13*2 FOR CPR
LDA R0L
SBC R0L,X
STA R0L,Y ;R0-RX TO RY
LDA R0H
SBC R0H,X
SUB2 STA R0H,Y
TYA ;LAST RESULT REG*2
ADC $0 ;CARRY TO LSB
STA R14H
RTS
ADD LDA R0L
ADC R0L,X
STA R0L ;R0+RX TO R0
LDA R0H
ADC R0H,X
LDY $0 ;R0 FOR RESULT
BEQ SUB2 ;FINISH ADD
BS LDA R15L ;NOTE X REG IS 12*2!
JSR STAT2 ;PUSH LOW PC BYTE VIA R12
LDA R15H
JSR STAT2 ;PUSH HIGH ORDER PC BYTE
BR CLC
BNC BCS BNC2 ;NO CARRY TEST
BR1 LDA (R15L),Y ;DISPLACEMENT BYTE
BPL BR2
DEY
BR2 ADC R15L ;ADD TO PC
STA R15L
TYA
ADC R15H
STA R15H
BNC2 RTS
BC BCS BR
RTS
BP ASL ;DOUBLE RESULT-REG INDEX
LDA R0H,X ;TEST FOR PLUS
BPL BR1 ;BRANCH IF SO
RTS
BM ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0H,X ;TEST FOR MINUS
BMI BR1
RTS
BZ ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0L,X ;TEST FOR ZERO
ORA R0H,X ;(BOTH BYTES)
BEQ BR1 ;BRANCH IF SO
RTS
BNZ ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0L,X ;TEST FOR NON-ZERO
BNE BR1 ;BRANCH IF SO
RTS
BM1 ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0L,X ;CHECK BOTH BYTES
AND R0H,X ;FOR $FF (MINUS 1)
EOR $FF
RTS
BNM1 ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0L,X
AND R0H,X ;CHECK BOTH BYTES FOR NO $FF
EOR $FF
BNE BR1 ;BRANCH IF NOT MINUS 1
NUL RTS
RS LDX $18 ;12*2 FOR R12 AS STACK POINTER
JSR DCR ;DECR STACK POINTER
LDA (R0L,X) ;POP HIGH RETURN ADDRESS TO PC
STA R15H
JSR DCR ;SAME FOR LOW ORDER BYTE
LDA (R0L,X)
STA R15L
RTS
RTN JMP RTNZ
;* SAVE/RESTORE ROUTINES
;* FOR NON APPLE-II SYSTEMS
ASAVE .EQU $45
XSAVE .EQU $46
YSAVE .EQU $47
PSAVE .EQU $48
SAVE
STA ASAVE
STX XSAVE ;SAVE 6502 CONTENTS *
STY YSAVE
PHP
PLA
STA PSAVE
RTS
RESETORE
LDA PSAVE
PHA
LDA ASAVE
LDX XSAVE ; RESTORE 6502 REG CONTENTS
LDY YSAVE
PLP
RTS
